My boss asked if we could make these snowblower augers so I’m trying to figure out what material they are made of. So far this is what I know: they are the auger ribbons on a huge dual engine Oshkosh snowblower. Each individual section is about 4” wide, 1/2” thick, and 48” long. They are helical in shape, like an auger flight. Appears to be a plasma cut 4” wide arc with about a 26” radius which is then formed to get the auger shape. There are 2 squares burned in each end for carriage bolts. Material has a Rockwell B hardness of 85. Material seams much more “springy” than mild steel- we tried to flatten one in a press to better estimate the geometry of a flat part before forming. It has way more spring-back than mild steel. Not sure if it has some kind of heat treatment?
I got it tested for composition at a local scrap yard, here’s what it said: unfortunately I didn’t see the machine had more than one page of info so I’m missing some…
Si 3.36
P .048
Ti .394
Cr .269
Mn 1.41
Fe 92.91
Ni.304
Cu .78
Local metal supplier suggested T1 but that’s way harder than this stuff. Any ideas? I’m told each part costs almost $900 from Oshkosh and they want me to look into making them or finding someone that can do it cheaper. Flame away gents, tell me how dumb I am
Si 3.36
P .048
Ti .394
Cr .269
Mn 1.41
Fe 92.91
Ni.304
Cu .78
