TTalma
- Aug 12, 2008
- FairPort, NY
I have a AXYZ CNC router, It is designed for cutting wood and Aluminum. I am cutting aluminum for the first time with it. The person I bought the machine from demoed it cutting aluminum and his cut edges were beautiful! This was a few years ago and I have no idea what settings or bit he used. My cuts don't look great (See pic).
My biggest issue is probably that I need to cut dry. I spray the bit with rubbing alcohol while its cutting from a spray bottle, and use air to get the chips out of the channel, but that doesn't get them all (about 75 to 80%).
I didn't take a picture, but I am making chips They are little squares, No sign of melting, and after cutting I can touch the bit without burning myself so it doesn't appear to be getting to hot. Cut time is about 7 min for this part.
I am cutting the parts out of a larger piece of stock, so the cuts are a full .25" wide. I am not taking a finishing pass. I used an online feed/speed calculator and believe I have the setting correct.
my machine, and settings details:
Onsrud 65-025 bit (.25" single flute upcut bit, 65-025)
.5" thick 8081 aluminum
6.6 hp spindle
12,000 rpm (This is the Min spindle speed)
40 in/min feedrate
.15" depth of cut
ramp in to cut at 5 degrees
Any suggestions on what to change?
6.6 hp spindle
40 in/min feedrate
.15" depth of cut
