HobbyMaker
- Feb 5, 2021
I'm looking into material choices to make a couple of draw bar style tools for my lathe:
Questions:
I have been looking at creating a some tooling from my old Nuttal lathe to improve the accuracy of a number of turning activities. The Lathe has a nice quick change D1-6 camlock setup on the spindle with a reasonable 3 jaw and 4 jaw chuck but the repeat ability of the 3 jaw is just not good enough to re-chuck parts. I was looking into mounting a ER32 collet on a D1-6 Camlock backing plate but not sure I could get the accuracy I'm chasing without re-grinding the spindle nose and re-dressing all the chucks and backing plates (not really a job for the faint hearted)
So it occurred to me I could make a drawbar and plug style mount for the centre on the quick change spindle (it seems to have some kind of taper in the centre of the spindle nose as yet un-identified)
These probably aren't going to be given exceedingly hard service life but I would like to prevent surface rusting when not in use as much as possible. It maybe possible to any old steel successfully for this but its worth putting a bit of though into because I hate having to make things twice.
- A headstock centre boss MT3 (Morse Taper 3) adapter for a dead centre for turning between centres with a draw bar setup
- A headstock centre boss mounted ER32 collet chuck
- Possibly other drawbar style chucks collet adapters in the future
Questions:
- What is the right steel to use for a job like this?
- 4140 Tool Steel jumped to mind as the right thing but I couldn't remember exactly why I thought this and $$$ per meter I thought there might be a better choice on a hobby budget.
- Tool Steel, Mild Steel, Low Carbon Steel, Alloyed steels etc
- Any insight on when to use what steel would be appreciated, specifically with reference to custom lathe tooling? (and if any specific use operations are required for given steels)
- Cold blueing, Oil, Water, Air Hardening Steel, etc
- I was proposing to case harden the steel and a little unsure if this was unnecessary from memory 4140 offers no benifit without heat treatment(?)
- I'm little concerned about order of operations if any thermal distortion occurred given the challenges of re-chucking and any possible need to surface grind after the fact.
My heating tooling is limited to an Oxy/Acetylene setup so it would be a case of chasing the correct cherry colour before quenching and I have had mixed success with this kind of operation.
I have been playing cold blueing lately, but not sure if it really offers the benefits of a true oil quench with respect to material properties and protections - Any insight or wisdom on the need or otherwise to go down this path would be appreciated?
