taiwanluthiers
- Dec 6, 2016
- Xinjhuan District, New Taipei City
I notice people talk about R8 tooling a lot, and I know that's what the Bridgeport mill uses.
When I was shopping for my mill (which is a NT40 taper) I asked about R8 and they never heard of it. The 40 taper is superior to R8 in every way. Has positive drive keys, doesn't lock up, and is completely interchangeable with BT40 CNC tooling (just take the pull stud off and extend the draw bar a bit).
So my question is, why doesn't mini mills use something other than R8? Why not NT30 taper (which is pretty close in size to R8 except it's got all the benefit of NT40 because it's a scaled down version anyways). In Taiwan, all the mills use either NT30 or NT40 tapers, nobody here uses R8 unless there's an import Bridgeport Series 1 that made it to Taiwan... even then I'm sure someone will have it converted to NT30 too, because if you show up to a tooling store looking for R8 tooling here they will look at you like you're from Mars or something.
