Who can manufacture this tapered steel tube? (Ford Axle Tube)
52 Ford
May 20, 2021
Pretty sure I know where two of those axle tubes are. What vehicle do you need the tubes for? The two that I know of need work, but the funky taper that you want and the flange that bolts to the diff is intact. ends of the tubes are messed up.
Edit: You're looking for tubes off a 30's or 40's Ford - right? I'll have to make a call tomorrow if you're interested. No promises.
standardparts
Mar 26, 2019
thanks for all your thoughts seems like I am back to where I began. "If it doesn't make dollars then it doesn't make sense." There is no space in this business plan for a loss leader this is a time-consuming and labor-intensive idea before we even turn the first wrench.a
Is this some kind of high school or tech school assignment where you make believe your bringing a product to market? Pick an existing product which appears to be a Winters quick change rear end and muddle through some sort of reverse engineering cost analysis. At least you could work up a basic drawing of the part with some specs.
Mud
May 20, 2002
South Central PA
Looks like we've been played again by someone who doesn't know much and isn't serious. Yet another reason why I don't visit here much any more.
