I am not aware of a polishing process being used to create a surface plate. Generally, after getting a good start with milling or a scraper or a lathe, the candidates for making a surface plate are scraping, grinding, and lapping.
You did say "metal" surface plates. Metal surface plates are a thing of the past: most today are granite or some other hard stone. The key here is "the past". One hundred years ago they did not have the modern machines for grinding and lapping. Those processes would have been a lot slower and a lot more expensive than scraping. Any power tools used would have been hand made for the process and probably not used for anything else. The tools for hand scraping are dead cheap. They can be made in almost any shop. And that is probably the key factor as to why the metal (cast iron) surface plates were scraped. Pure economics. Cheaper tools and less labor.
BTW, some of the most accurate surfaces in the world are and were made with a lapping style process followed by polishing. They are better than scraped surface plates ever were. They are optical surfaces, both flat and spherical. And they are made from glass or other, more exotic optical materials. The process is DEAD SLOW and therefore EXPENSIVE. And the people who do it call it grinding, not lapping. Read the story of the making of the 200 inch mirror for the Mount Palomar Observatory. Grinding and polishing of that surface took 13 years. And they DID use machines; they had to for something that size.
Hale Telescope - Wikipedia
Even a small optical surface can take hundreds of hours to grind and polish to it's final shape. And they DO use a POLISHING process that is even slower than the grinding/lapping to get the final surface. I made a 6" telescope mirror and it took many, many hours just for that small size. Those telescope mirrors are spherical or parabolic and are made with the mirror blank and one tool. Going for a flat surface would take longer because three surfaces would be involved instead of just two.
You can talk all you want about this advantage or that disadvantage or problem with the various methods, but the real reason why the metal surface plates were scraped was pure economics. It was the cheapest way.
Greetings all.
It has been a while since my last post. Been a bit busy with work, rather than just fun stuff.
Anyhow, I had a question I meant to ask, but havn't.
Why are the metal surface plates scraped instead of polished?
I understand the benefits of a scraped or flaked surface for oil retention on a load baring surface; and I realize that scraping is much faster than fine grit polishing.
However, the granite surface plates are polished... Why are most if not all metal surface plates are scraped instead of polished?
There is really no reason for surface plate to be a heavy load baring surface. No reason for oil retention as offered by scraping / flaking. Why not polish metal surface plates? Never seen one polished...
