Hi AD Design:
A jig grinder will still produce a better hole for an application in which you are going to stress the corner, (like the die opening in a punching station) than a wire EDM will, (especially in carbide) but the gap is steadily closing and the quality of a wired hole is getting very good indeed.
However, the major benefits to the wire over the grinder are pretty obvious:
1) Your desired shape need not be round and the level of skill needed does not really change if it's not...unlike with a jig grinder, even a CNC jig grinder.
2) You can make ridiculously unfavourable aspect ratio features to an excellent level of precision, and you can make very small corner radii easily.
A different skill and knowledge set is required, and it's less experience dependent...I can whisker off a tenth a side in a 1/4" diameter hole 6" long just by changing the wire offset and pushing the green button again, and with only a few caveats, it will do it reliably and accurately, and I don't need to hire vast, almost unobtanium skills and experience to make as many of these difficult and super accurate holes as I may want.
3) The setup to put features in their proper relationships is a small fraction of what's needed to grind, as soon as the features are not round.
On a wire I can do things easily that are impossibly hard to do on a grinder; as an example I've been making gears for the robotics guys lately, and I can get the pivot bore concentric to the pitch circle within a tenth without breaking a sweat simply by wiring both bore and teeth in the same setup.
I can also get the tooth form and tooth spacing to a similar tolerance ridiculously easily and I can do it in a 6" tall stack of gear blanks with internal corner radii of 0.010".
So yeah, those who claim a jig ground feature to be the best, have some valid points, but wires are getting awfully good, and they're pretty easy to use too.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
