eKretz
Diamond; Mod Squad
- Mar 27, 2005
- Northwest Indiana, USA
ID = Inside Diameter. OD = Outside Diameter.
Apologies if this isn't the right Forum, but I reckon someone in your group knows more about this than I do!
I am currently working on a Triumph Spitfire. One of the wheel studs has stripped most of its own splines and rounded out its hole on the flange plate.
Pulling the plate isn't likely (I don't really want to buy an expensive Puller for one job, and they are a total b*stard to get off!).
Tack welding the stud might be an option, but I'm not a welder!
But then I came across a post on your forum called Loctite info thread - StuMc was involved in the discussion.
Does anyone know if this would work? The new stud is going to be a reasonably close fit in the hole. Would something like Loctite 603 (or similar) bond with sufficient strength to withstand my torque wrench when I refit the hub and spline adaptor (the Spit has 'knock off' wire wheels so isn't secured directly by the studs).
Thanks in advance for any advice!
Thanks very much for the advice and I'll put your question out on the restoration site I use.660 works well for what you want. I would loctite the stud in place, I've used 660 a few times and it's quite impressive stuff. Especially if you don't intend on removing the stud.
Have you checked to see if there arent any studs availible that have over size (diameter) splines? You can't be the first Spitfire owner who's had this problem.
0
Thanks very much for the advice.Loctite 680 is some strong stuff, fully cured it has a rating of 4000 pounds shear strength and will fill up to .015 gap.
And the relevance of this to my question is.....?I had a Triumph Spitfire Mk III.....this was the worst POS to ever sit on four wheels .........something would break every time I drove it .......Incidentally,these cars are no relative of the Triumph cars with the 2l motors.............they were a cheap POS that was also called the Austin Healy(Bugeye) Sprite ,and the MG something or other..............the darkest days of the destruction of the British motor industry.
OD stands for Old DoggerApologies I'm not familiar with OD and ID....Outer/Inner Dimension maybe? Is this to give the Loctite a surface to bond against? Thanks!
Notice
