Lee Stough
- Feb 3, 2022
I have a Komo router controlled by a Fanuc series O-M,a computer with windows 98 program Hyper Terminal to send files to the Fanuc. I am getting, on the Fanuc, error message 087 “buffer overflow” when I try to send a file.
I’ve been sending “out files” for years with no problems. A cable came loose, and before I discovered the problem I changed some settings in windows 98. One, of several things I did, was change the settings for Comport 1 to the default settings. I called Fanuc technical support. They told me if Fanuc parameter 552 was set to 11 (which it was) then the Bits/sec setting on comport 1 needs to be “9600”. Also if parameter 1 ends in 1(which it did) then set Stop bit to “2”. The other settings are: Data bits “7”, Parity “even”, and Flow control “xon/xoff”. After correcting the settings I still get the 087 error. I read a response to “Johnny” by “Gar” that the FIFO needs to be disabled. In comport 1 advanced settings I unchecked the FIFO box. I still get the 087 error. If anyone can help I will be very grateful.
Thanks
Lee
Thanks
Lee
