Pattnmaker
- Nov 2, 2007
- Hamilton, Ontario
Instead of using babbitt I would give body filler a try. Use it to fixture prevent chatter etc. Then clamp in a place or two...
I have wondered about this in the past too... Will a fixturing alloy hang onto a flat surface though? There's no real areas for the material to 'key' into on the underside of the knife and I've never been sure if it will hang onto a flat surface... I actually bought some special thermoset 'hot glue' (a urethane based one) last year with the idea of trying it for the same purpose. I found it didn't hang onto the blades as well as I would have hoped, but I might need to try again with the blank pre-heated or something.
Does the alloy have to grab onto the flat surface? Almost all of the material removal is done while it's in the picture frame. All you need the alloy to do is support the material during the final profile cut, by which point you have lots of pockets in the handle for the alloy to grab onto.
This actually reminded me of an article I saw a while ago on an adhesive fixturing setup: Shop Finds Fixturing Solution for Flexing Parts |
Modern Machine Shop
One thing that might make this easier is that the blade edge area does not really need to be finish machined as I sharpen that area away anyway, so perhaps I could mount toggle clamps overhead in that area to hold the blade down. That would potentially be fairly simple and only require a single customized fixture per blade shape... I was mucking around with this concept a little last week:
The idea being that I would machine the blade in the 'picture frame' similar to what I show in my first post, but I would cut out the outline oversize and leave tabs, then finish the outline in this fixture. The red marker indicates the areas where I would take a finish cut. The biggest issue I see is that the toggle clamps are fairly tall which would get in the way of having nice stubby tooling, but perhaps a different kind of clamp or something could be used.
Notice
