L
Luke.kerbey
Guest
Hi Folks,
Of late I’ve started doing taller work pieces than I’m used to.
I cut a lot of stuff up to 75mm with no issue at all.
This last job was a 300mm brass outer diameter of 65mm pre machined and I had to bore the centre to 55mm.
The job held well in the work holding and took 8 hours in total.
My only two problems are
The centre was under size by around 20 microns per side.
The top 50mm over cut on the first cut by around 70 microns a side.
The over cut is my biggest problem. I didn’t scrap the part but how can I preempt this overcut and reduce it?
Is it flushing too high?
My conditions only go up to 150mm for copper based. Should I make my own condition for 300mm material?
What could have caused this?
I’ve not got dozens of these to try and perfect on so any tips would be appreciated.
