michiganbuck
- Jun 28, 2012
- Mt Clemens, Michigan 48035
You might give your tool post and even your compound a reasonable whack to see that all is solidly fixed. *Yes with the likes of a paint mixing stick as a whack-on cushion so as not to mar or break something. Could be a bolt is too long and bottoming out so not tightening something down solid.
Cutting forces could be easily 100 pounds or a few hundred pounds and that can push something that is not bolted down tight. An easy pull on a 3/8 bolt might be 1000 pounds of force pulling something tight..and a lathe may need 1000 to keep the tool post from turning. A bottom-out bolt may be lacking the force needed to pull something down.
QT:{ people that have grinders dont use them much is the feeling Im getting here.] Because lathes are not designed for abrasive grit and so the grit gets into the lathe worked and causes high wear.
How does the top of your lathe bed V way look? could it be bottom out at the top of the V. Ways so wore out that the portion that should have contact does not have contact so riding on the top of the V way.
Or another way to say this is the saddle riding on the bed ways as it should. *You should see oil wiping evidance.
