zac_b
- Mar 9, 2013
- Brooklyn, NY
And have some questions for folks with experience with the internals:
Q1 - Variable-speed belt drive:
The floating steel double-taper sheave (is there an official name for that?) in the center of the Reeves-style drive seems to ride on a bronze bushing. Problem is, the sheave slides freely on the bushing (first picture).
My thinking is this shouldn't happen, as it could mean that the sheave wobbles as it slips partly off the bushing (hypothesis potentially corroborated by the 36" of belt reinforcement I unwound from the central hub).
So, I got some Loctite 680 retaining compound (second picture) which should hold it nicely once cleaned and fixtured.
I just wanted to check that I was doing the right thing, as this is one of the assemblies that Deckel apparently felt shouldn't be user-serviceable and so the operator's manual skips right over it. Also, any clever tips on centering and squaring the bushing before gluing it in place would be appreciated - I was just going to nestle the cone into a big bearing race, space up to center, and run a DTI around the edge to check wobble.
Q2 - Drag table bellows:
Got lost somewhere along the way. Does anyone know if it's worth pinging Germany (Singer, etc...) for replacements, or have ideas for jury-rigging substitutes? I'd rather not get the little bearings in there all full of chips.
Q3 - Spindle removal:
Spindle is - I think - in good shape, but appears to be seized into the casting. A) is it worth removing, or should I just resign myself to servicing it in place when necessary? (I don't currently have other spindles to swap in, so that bit is a moot point). B) if worth removing, any bright ideas for getting it out? Force and heat are both contraindicated, and there's precious little to grab onto...
Q4 - Belt choice:
The variable drive came set up with some pretty worn but standard stock v-belts, and I picked up replacements accordingly - any known issues with using plain old 4L belts instead of ze spezial-vari-expensive belts I'm sure were initially specified? (Also the same question for the final spindle drive belt except it's a 3L). See pic - old on bottom, new on top.
Q5 - Stylus collets:
Are these just GK-21 (et. al.) Deckel collets? Anyone know where some might be found for less than $80/ea and shipping from Germany?
Last question: know it's a long shot, but if anyone has KF accessories they're interested in selling or trading, PM me or drop a note here.
I'll try and keep machine repair all in this thread, unless it gets too unwieldy, but will start another for projects as soon as the drive is fixed & everything's reassembled!
Q4 - Belt choice:
