WOT- fiberglass splinters can't be removed!
challenger
Mar 6, 2003
Hampstead, NC-S.E. Coast
I recently made a stake pole for kayak fishing by joining two 5/8X40" fiberglass rods together. These rods have been damage by UV and were somehow rough as the original gell coat was gone. I had to handle these quite a bit and ended up with several fiberglass splinters. Most came out easily but I have a fww, really annoying, splinters in my fingers that I can't see and, so far, remain stubborn.
Any tips other than wait?
Thanks
I wonder if peroxide would bubble at the area the splinter penetrates.
Maybe alcohol would sting and help you pinpoint the exact location?
I had a long oak splinter that was in a finger tip. Kept squeezing every day.
Took about a week and it suddenly popped out. Was about 5/16 long.
Just keep the squeeze on and you can see the fluid at the entry.
If you don't apply some Italian persuasion the skin might heal up and you will be an embedded system.
What's probably happening is that the wound in which the splinter now resides has become infected, which is loosening and slowly expelling the splinter.
I had road rash all over my back, the imbedded rocks and dirt that the fat 50 year old nurse that hated motorcycles failed to clean out with her scrub brush worked their way out through the skin for about 2 years. Your splinters will come out eventually.
I have a real glass splinter in one of my fingers. It's been there since 1976. Besides a minor disruption in the fingerprint I scarcely know it's there.
In my experience, just leave it alone. I've done more damage digging things out. The few impossible to find splinters I've had healed over and stopped hurting, and formed a kernal around it that migrated to the surface and eventually broke through the skin and fell out.
I think so long as it isn't below a callous, and most of the splinter is above the innermost layer of the skin, it will migrate out on it's own. A hard kernal (like a callous nugget, or a skin pearl) will form if it is irritating the skin and then it stops hurting.
When I was working in GF both laying up and subsequent machining, despite PPE, I got the problem mentioned by the OP, I found that the best solution was to shower in cold water to remove the loose bits then hot to open the skin pores and wash off the bits.
The guys working with me found this worked for them also. After a few days the itching became less.
That hurt just reading it
