I'm thinking that I would like to purchase a shear. The main use would be to shear between 16 and 20 gauge steel sheet up to 48" wide and possibly some aluminum in that range or slightly thicker. I'm thinking a simple stomp shear would probably suffice.
That being said, the ability to shear up to 1/8, 3/16 or even 1/4" would really be useful at times as well. A 1/4" capacity with a width capacity of 4,6 or 8 feet would probably be about the max I would consider but I have a few questions in regard to one of that size. First would be my floor as a shear this size can be heavy. Would something this size require some sort of foundation? My floor is 5" thick 6.5 bag mix concrete with wire. I do not want to have to break out any floor and redo anything for whatever shear I decide to go with. Any thoughts on this matter?
I am also somewhat limited on the electric end as well so the max. HP I could run would be in the 7.5 or possibly 10 HP range.
I have little knowledge about metal shears so any advice or recommendations as to things to consider or machines to avoid and so forth would be greatly appreciated.
Jeff
Jeff
