Hi A.Delaney:
If you don't need the flange it's an easy part for the wire EDM.
The OD teeth will need a jig to hold the parts for finish cutting two of the teeth if you need them accurate, but it's not a difficult job.
You could stack plates and cut several at a time.
Remember though, you will have 0.005" radii on all the internal corners, both on the ID and on the OD.
If you can't live with that you can undercut the corners with a shallow 0.010" slot into each corner.
If you can't live with that either, you can't make them on the wire.
Cheers
Marcus
Implant Mechanix • Design & Innovation > HOME
Vancouver Wire EDM -- Wire EDM Machining
