mattthemuppet
- Apr 22, 2016
- San Antonio
Yuasa Accu-Dex 8" super spacer 550-007 Made in Japan, plus spacer plates + tail stock
Thought this would work on my 6x26 mill, boy was I wrong!
This is a REALLY nice 8" super spacer by Yuasa. Made in Japan with a set tru chuck. #550-007. The tailstock is 553-301. Spacer, chuck and plates alone list for $2k online, so it's a quality bit of kit.
In good working condition. Indexing and chuck locks work well, chuck spins smoothly, chuck jaws screw in an out fine with a couple of catches (probably gunk in the scroll). Tail stock quill is a little stiff with the lock off, so it might need a clean and re-oiling (or it might just be like that). Comes with 2, 3, 4, 5, 6, 8, two 12s and a couple of oddballs. There are another 9 plates that are either duplicates or oddballs, which you can have if you can use them if you don't mind paying the extra shipping.
Asking $500 plus actual shipping and the materials to make a crate. My zip is 78254, net weight is 140lb for the stuff in the pics (add another 10lbs maybe for the extra plates). I'd guestimate 15-20lb for the crate.
