A Machine Shop Poised for Additive Production
September 23, 2019 9:36 am
By laying the groundwork now, Able Tool will be prepared for the day when machine shops are commonly called to produce metal parts via additive manufacturing.
Article From: 8/30/2019 Modern Machine Shop, Emily Probst, Managing Editor
mmslogo
If you would’ve visited Able Tool before 2003, you never would’ve pegged the Cincinnati-area machine shop as one actively investing in the latest manufacturing technology. Back then, a quick glance around the shop would show mostly toolroom-style equipment. However, that began to change when Paul Hayes took over as company president. For the business to thrive, he knew the operation would have to take a quantum leap by adopting much more advanced technology. Today, Able Tool’s shop floor consists of four- and five-axis machining centers and large horizontals and wire EDM. On-machine spindle and tool probes have reduced setup time on that equipment and enables in-process inspection for more effective process control.
The company’s commitment to adopting new technology didn’t end there. About six years ago, Mr. Hayes decided to take additive manufacturing from a concept he’d researched to a process he could possibly apply on his shop floor, ultimately moving quickly from 3D printing plastic parts to printing metal parts. To be certain, there’s a case to be made for printing each type of material, depending on the application, he says. In both cases, though, Mr. Hayes believes additive technology has helped his company better serve its customers by reducing the number of steps it takes to move from design to produced part. “Really, it’s just another arrow in our quiver, so to speak, to make things as efficient and cost effective as possible,” he says.
Not to sugar-coat it, investing in additive manufacturing was a risky move for Able Tool. While there is a clear ROI for more advanced machine tools and related equipment, additive technology’s ROI is murkier, especially for a shop not immediately using it for production. Yet, Mr. Hayes was determined to make sure Able Tool wasn’t in a position of playing catch-up again. In order to get ahead of the additive learning curve, he decided to take a leap of faith.
The Metal X is a fused-filament fabrication printer that builds parts by laying down layers of material, until a part builds up. Photo: Paul Hayes
Graduating to Plastics
Able Tool is a milling, machining, fabrication and assembly shop that specializes in high-mix/low-volume production for a range of industries, applications and materials. Its facility boasts large horizontal mills, vertical machining centers and vertical turning lathes. Increasingly, the shop has been involved in full machine assembly, integration and testing rather than just individual part production.
Although additive capabilities are relatively new to Able, Mr. Hayes began looking into the technology about 15 years ago. He even hired a consulting firm to see if metal 3D printing technology was something his company should invest in, and two separate groups told him no. “They were probably right given the manufacturing environment at the time, what our company does, and the value associated with additive technology,” Mr. Hayes says. “None of those things aligned.”
Not to be deterred, Mr. Hayes continued to study the technology, convinced of its potential. Six years ago, he decided to purchase a MakerBot 3D plastic printer because it was a relatively small investment, the machine could sit on someone’s desk and no ancillary equipment was necessary. With the only consumable being the plastic material, Mr. Hayes says the MakerBot was a low-risk option for hands-on learning. If a part didn’t turn out as planned, or if it had to be scrapped, he didn’t have to worry about throwing away a high-priced metal experiment.
Four years later, Able invested in a Prusa 3D printer to produce closer-to-end-use parts. Two main features drew the company to the Prusa, says General Manager Mike Trovillo. First, it can print with more than one variety of plastic. Second, its heated build platform keeps the plastic warm to prevent warping. The company has used this machine to make a couple end-use parts for its customers, such as end-of-arm tooling for a robot and part nests for a CMM. Mostly though, Mr. Hayes says he uses it as a low-cost option for proving out concepts that would take time away from other jobs on his CNC machining centers or be cost prohibitive to make in metal. In some cases, the application simply merits a plastic solution. For instance, during my visit, a summer intern was working on the second iteration of a design for a two-piece manifold that would attach around the spindle housing of a large boring mill to help better distribute coolant to the point of the cut using coolant flex hoses that attach to it.
This was the first iteration of a two-piece, 3D printed plastic coolant ring designed to better distribute coolant to the tool tip on Able’s new boring mill. The problem is that the coolant manifold sits far back from the spindle, where the tool is. This device is designed to clip onto the spindle housing, allowing coolant to flow through its inner chamber and come out the two rings onto which Loc-Line flex hoses snap. Coolant can then be directed more efficiently to where the tool engages the material.
Able to Print with Metal
After gaining experience with printing plastic and seeing the technology that was emerging, Mr. Hayes decided the time was right to take the next step and begin 3D printing metal parts. “We had to rip the Band-Aid off and at least try to understand how we could use metal additive technology and sell it to our customers,” he says.
The Metal X uses both metal and ceramic powder to 3D print parts. The material comes in spools of powder encased in plastic for easier handling and a lower melting point.
Though Able Tool had been building up to this moment for years, actually buying its Metal X 3D printer from MarkForged was a sudden move. At the end of last year, Mr. Hayes jumped on the opportunity to buy the new machine from Reynolds Machinery in Dayton, a new MarkForged distributor.
Despite the swift timing, Mr. Hayes was confident that this was the right decision for his company. Rather than choosing a laser-sintering or powder-bed machine, which would require a special lab environment, the Metal X has a lower barrier to entry and can make complex parts in its 300- by 220- by 180-mm build volume, he says. Also, learning from his experience printing with plastic, he knew he wanted the freedom to print with a variety of metals. Currently, the Metal X can print 17-4 PH stainless steel, H13 and A2 tool steel, but MarkForged plans to soon add the capability to print D2 tool steel, titanium, Inconel, copper and 316 stainless steel (which Able is particularly interested in) in the near future.
MarkForged provides this flow chart to guide users through the washing/sintering process. A printed part must be weighed before it goes into the wash in order to compare the percentage of mass lost during the washing process. Paul Hayes writes that weight on the bottom of the part for tracking purposes. If more than 4.2% of mass is lost, the part can be sintered. If not, it might need to be washed again.
The Metal X is a fused-filament fabrication (FFF) printer that uses spools of  metal powder and binding agent enclosed within a plastic encasement. The second spool is ceramic powder enclosed within a plastic encasement. It works by feeding those spools through a heater block, where it is heated to the encasement’s melting point and fed through an extrusion nozzle. The nozzle first lays down layers of material mixed with ceramic where necessary, which will later act as the part’s release. (The ceramic can also be used to build support structures that once again will be removed at a later point). The nozzle then lays the metal on top of that, building the part layer by layer. The machine uses disposable print sheets that are held down by a vacuum table to improve bed adhesion and ease part handling. Once a part is printed, the paper is easily removed from the vacuum table. Able Tool’s typical batch sizes range from one to four parts. However, Mr. Trovillo says that if a part is small enough, he estimates that he could fit as many as 30 parts on the build plate. “It really depends on the size of the part,” he says. “You can print whatever fits in the build volume.” The shop’s smaller parts print in about two to three hours, while the larger parts can take several days, depending on part mass and complexity.
Before building a part, the printer lays down a support raft, which will act as the part’s release. The print sheet is held by a vacuum to the print table to make part handling easier. Photo: Paul Hayes
Printed parts are weighed on a digital scale before being submerged into the MarkForged Wash-1 heated washing system, where Opeteon SF-79 cleaning fluid circulates around the parts to break down most of the plastic and wax binding agent. After washing, the air-dried part is weighed again to determine if a high enough percentage of the binding agent has been removed. If not, it goes back into the wash to remove more binder. If it has, the part is considered ready to be sintered.
For Mr. Hayes, one of the advantages of using the MetalX was that it is basically a pre-packaged system – MarkForged supplied the printer, washing system and sintering oven, and directs shops in the specifics of how to set them up, paying close attention to ventilation, equipment spacing and sintering gas mixture requirements. MarkForged also offers its Eiger 3D-printing software, which Mr. Hayes says is very easy to learn. Once a part is designed in CAD software, its STL file can be uploaded to the Eiger software, which uses algorithms to automatically compensate for the shrinkage a part experiences during the sintering process. The Eiger software enables him to manipulate the part and see the dimensions, print time, wash time, sinter time and more.
Able Tool keeps its 3D printing system mostly inside this vented room on its shop floor. After printing a part, the part is weighed and taken to the washing system outside the room (foreground). It is then air dried and walked back into the enclosure to be reweighed. From there, it goes into the sintering machine, located almost in the middle of the room, to fuse the metal. A large argon tank for the sintering machine is located in the corner to the left of the Metal X.
A Brave New World
Within a week of Able purchasing the Metal X, the printer began to open doors for new business. A medical customer happened to notice it during a tour of the shop and began asking questions about its capabilities. Not only did that client award the machining work it came to investigate in the first place, but it also gave Able a job printing a metal prototype for a part – marking the first time the company had done any work for that customer.
Other customer prototypes are usually the result of Mr. Hayes printing parts for his customers as a surprise to show them what this alternate part-production technique is capable of. But for now, Able mainly uses the Metal X printer for custom fixturing to be used around the shop. According to Mr. Hayes, use of the metal 3D printer intentionally has been a slow, organic growth path. In fact, the shop doesn’t even promote its additive capabilities on its website yet. “I want to be able to go to a customer with certainty and say that we can produce the part you want before we officially promote the capability,” he says.
Moving forward, Mr. Hayes hopes to use metal 3D printing capabilities not to go after new business per se, but to solidify the relationship he has with his current customers by helping them see design improvements and ways to produce parts more efficiently. He believes additive technology refinement will continue to the point in which it is just part of a machine shop’s everyday operation. Mr. Hayes predicts that most machine shops will have a 3D printer at some point, much like they have an three-axis VMC.  “I believe the integration of additive technologies into a job shop environment is a matter of ‘when,’ not ‘if.’ We need to understand how to use these tools to meet our customers’ needs. That’s why we bought the machine.”
Five Tips for Beginners
On the cusp of going public with his shop’s metal 3D printing capabilities, Mr. Hayes offers this advice for other shops considering the technology:
1. Start with plastic. It’s a simple matter of economics: Plastic is cheaper than metal. Even if your end goal is to 3D print metal production parts, it’s easier to learn (and make mistakes) in a medium that isn’t so costly.
2. Research surprise costs. Aside from the upfront costs associated with purchasing a 3D printer, there are other ancillary costs to consider. For one, the argon gas is expensive, and if you don’t have a working relationship with your supplier, you might have to wait longer than expected for a refill while your sinter sits idle, Mr. Hayes says. You must also realize that even if you don’t use the gas, compression will make the gas bleed out. “Once you’ve purchased your 3D printer, you’re in a ‘use it, or lose it’ situation in terms of the gas,” Mr. Trovillo notes.
3. Find the right spot. Don’t let the small footprint of a 3D printer fool you. Just as much forethought should go into the machine’s placement as you would give a VMC or HMC. Consider electrical and ventilation requirements. Consider possible workflow of parts from your printer to secondary operations on your shop floor. Able converted a small CMM room into the company’s metal 3D printing area. “Unfortunately, we didn’t consider the fact that you need 12 inches of space surrounding the sinter,” Mr. Trovillo says. That meant the wash station wouldn’t fit into that room. “The outcome of this is that we have to exit the 3D printing room to access the wash station, which had to be positioned just outside. Once washed, the parts must be walked back into the room for sintering.” While this isn’t a make-or-break issue, a little forethought would’ve saved a minor workflow annoyance.
4. Learn how to correctly price parts. It’s not as easy as you think. Mr. Hayes says that while the Eiger software lets him know how much material he is using and a part’s run time, there’s more to quoting than that. “You still need to figure out the charge rate for the machine and how much gas and cleaning fluid you are using. Shops need to figure out what their actual operating costs are.”
5. Think like an engineer. “Integrating 3D printing into your facility is more of an ‘engineering learning’ than a ‘manufacturing learning,’” Mr. Hayes notes. It’s important to understand what the end result is to be and how to design the part to net that out. You may need to consider revising your design to fit the capabilities and limitations of your machine.
MMSOnline Blog
