Allied Machine Promotes High-Penetration Insert for Structural Steel at FABTECH
October 22, 2019 11:10 am
GEN3SYS XT Pro structural steel insert withstands the heat and extends tool life.
Chicago, IL – Allied Machine & Engineering, a leading manufacturer of holemaking and finishing tooling systems, will display their newest GEN3SYS XT Pro high-penetration insert designed specifically for structural steel applications at FABTECH in booth #A3491, September 11th – 14th, 2019. With a proprietary blend of substrate and multilayer AM420 coating, the insert is composed to withstand the extreme heat produced while drilling in structural steel beams or plates in high production facilities. Allied’s XT Pro structural steel insert is designed to run most effectively in our GEN3SYS XT structural steel holders, improving both chip formation and tool life while reducing vibrations to create a higher quality hole.
While Allied’s entire XT Pro product line thrives in high-penetration drilling applications, this unique combination of carbide grade, geometry and high-temperature coating is designed to run at or beyond current O.E.M. rates in structural steel applications.  The insert’s simplified setup and extended tool life reduces changeover and increases throughput. Their upgraded carbide insert has been completely redesigned to improve throughput and cut operational costs by extending life and increasing penetration rates. To preview the GEN3SYS XT Pro structural steel insert in action, watch this brief demo here. For more information about Allied’s GEN3SYS XT Pro insert created for structural steel drilling applications, please call 330.343.4283 or visit www.alliedmachine.com/XTPROST.
About Allied Machine & Engineering:
Allied Machine & Engineering is a leading manufacturer of holemaking and finishing tooling systems. Allied devotes its advanced engineering and manufacturing capabilities to creating the widest selection of value-added tooling available to metal-cutting industries around the world. Our tooling solutions deliver the lowest cost per hole in a wide range of drilling, reaming, threading, boring, and burnishing applications.
Located in Dover, Ohio, Allied’s precision holemaking technologies provide end users worldwide with the highest level of drill performance. Precision engineering and expert application support make Allied the first and best choice for solving complex metal-cutting challenges.
