New Seco High Feed Square Cut Size 14 Milling Systems to Tackle Difficult-to-Machine ISO P, M, and S Materials
October 5, 2021 2:19 pm
Seco Tools has launched a new High Feed cutter and insert series in size 14. Increase tool life and maximize the value of every edge with this new series in stainless steels, titanium, and superalloys milling applications. The High Feed Square Cut size 14 milling system is ideal for tough materials and comes in a full range of proven Seco Tools grades made to achieve fully secure, and optimized high feed milling.
The single-sided, straight edge insert geometries allow you to push your high feed milling speeds to new limits. Ensuring high feed per tooth whether ramping, pocketing, plunging, or performing face or copy milling, this new solution creates great chip evacuation and makes it easier than ever or handle difficult machining operations or milling in deep cavities.
Not only does this solution make it easier to machine sticky materials, but it is designed for easy, ergonomic indexing and the pocket and screw designs simplify positioning. The cutters themselves feature a new environmentally friendly coating and their outstanding high feed milling performance reduces the amount of power used in roughing. Yet another step in the right direction for Seco Tools to continue their journey to create more environmentally sustainable manufacturing and machining solutions.
For further information on the new High Feed cutter and inserts please contact a local Seco representative or visit the High Feed Square Cut Size 14 milling system product page.
With its origins in Fagersta, Sweden and present in more than 75 countries, Seco Tools is a leading global solution provider of metal cutting solutions for indexable milling, solid milling, turning, holemaking, threading and tooling systems. With the hands-on application advice of Seco Tools, the company drives excellence for more than 80 years throughout the entire manufacturing process of manufacturers by ensuring high-precision machining and high-quality output. For more information on how Seco innovative products, expert services, knowledge and experience bring success to manufacturers across all industry segments, please visit www.secotools.com.
Seco Tools LLC
2805 Bellingham Drive
Troy, MI 48093
United States
Wojtowicz Julie
Phone : (248) 3080389
Fax : –
[email protected]
Seco Tools AB
PALMEN Bettina
Phone : +49 211 24 01 313
Fax : +49 211 24 01 275
[email protected]
