Walter Unveils the XTRA∙TEC® XT M5250 Helical Milling Cutter with BC System Inserts
May 31, 2024 8:12 am
The Walter full-effective helical milling cutter provides a high level of process reliability and is suitable for full slotting.
Greer, SC — Walter has introduced the XTRA∙TEC® XT M5250 helical milling cutter, which is available in 2″, 3″, 50 mm, 63 mm and 80 mm diameters and is being offered with two different depths of cut per cutting diameter.
The full-effective design enables a high metal removal rate and delivers a smooth milling operation for the indexable inserts which are available either ground or sintered. Walter uses proven, double-edge BC 1605 system inserts on the face of the M5250. These inserts allow users to choose between various corner radii, cutting tool grades and six geometries. The milling cutter-specific SC 1105 inserts with four cutting edges serve as circumference, or peripheral inserts and provide excellent operational smoothness.
XTRA.TEC XT M5250 helical milling cutter
The G51 geometry, labeled “The quiet one” is ideal for tools with long overhangs or applications that are likely to involve vibration. When machining a high volume of titanium, the G55W WaveCut geometry is the first choice.
Walter’s latest generation of indexable insert milling cutters is distinguished by high performance combined with a high level of process reliability due to the optimized insert pocket design. In addition, each individual tool on the XTRA∙TEC® XT  M5250 is cooled separately.
The M5250 cutter is effective for milling steel, cast iron, stainless steel, aluminum and other non-ferrous metals (ISO P, K, M and N workpiece groups), as well as materials with difficult cutting properties. Unlike other full-effective helical milling cutters, the XTRA∙TEC® XT M5250 can also be used for full slotting, shoulder milling, pocket milling and ramping. The positive rhombic basic shape of the face insert makes ramping possible.
The tool reduces process costs because of the two or four cutting edges per indexable insert and the use of the latest wear-resistant Tiger∙tec® cutting tool materials. In addition to machining aerospace components, applications include producing energy parts and general mechanical engineering.
Walter, a global leader in the metalworking industry for over 100 years, offers a wide range of precision tools for milling, turning, drilling and threading applications. The company helps customers in the aviation and aerospace industries, automotive, energy, and general metalworking industry improve process reliability and increase productivity. As an innovative partner capable of creating digital process solutions for optimal efficiency, Walter is pioneering Industry 4.0 throughout the machining industry. With Regional Headquarters in Greer, SC, Walter markets its competence brands Walter, Walter Titex, Walter Prototyp and Walter Multiply through a network of channel partners and field engineers across the USA, Canada, Mexico and Brazil. www.walter-tools.com/us.
WordPress database error: [Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (utf8mb4_unicode_520_ci,COERCIBLE) for operation '=']
SELECT a.*, b.*, customavatar.filename as customavatar, user.avatarrevision, postparsed.pagetext_html as cachetext, ( SELECT COUNT(x.postid) FROM vb_post x WHERE x.visible = 1 AND x.threadid = a.threadid ) as scVBTotalPosts FROM vb_thread a LEFT OUTER JOIN vb_post b ON b.threadid = a.threadid LEFT OUTER JOIN vb_customavatar customavatar ON customavatar.userid = b.userid LEFT OUTER JOIN vb_user user ON user.userid = b.userid LEFT OUTER JOIN vb_postparsed postparsed ON postparsed.languageid IN ( SELECT MAX(x.languageid) FROM vb_postparsed x WHERE x.styleid = postparsed.styleid AND x.postid = b.postid ) AND postparsed.styleid IN ( SELECT MAX(x.styleid) FROM vb_postparsed x WHERE x.postid = b.postid ) AND postparsed.postid = b.postid WHERE a.forumid='59' AND b.visible=1 AND a.title='Walter Unveils the XTRA∙TEC® XT M5250 Helical Milling Cutter with BC System Inserts' ORDER BY b.dateline DESC LIMIT 20
