10 x 20 universal od id grinder od spindle cartridge
jim may
Oct 24, 2014
Houston
Thought I would post this here and see if anyone has experience with Norton Od grinders
Our grinder is a universal OD with a fold up ID
We want to pull the od grinding cartridge out. Do these have a set screw holding the
cartridge in?
Anybody point me in the right direction or someone who has done this before.
Do get the book.. I remember a colonial broach grinder that had wedges that choked up to a groove in the cartridge. You would pull the screw then knock in to relive the far wedge... then go into the same hole with a larger thread, start the thread, and pull out the close wedge.
I went to get the book and before I got back the mill wrights broke the wheel head casting with a short 4x4 and sludge hammer.
Ok I had a salesman from GCH send me a print of the head and cartridge.
It is a cartridge with a bolt on flange. We got it to move a little bit
but it must be rusted in so will keep at it
Thanks for all the comments
Tap it back and forth lightly with a force that won't break any thing. Use a little WD perhaps.
If it goes just so far easy then gets solid look for more.
[a cartridge with a bolt on flange.] more details pleas just in case I should get one.
