Acer 1020 hudraulic surface grinder crossfeef
Likes Likes:  0
Results 1 to 4 of 4
    Jul 2019
    Default Acer 1020 hudraulic surface grinder crossfeef
    I have an Acer 1020 ags hydraulic. The auto cross feed only works if I hold down the button on the control panel. I can put it in hand mode and move it back and forth. When put in auto it only moves the amount I set it to but like I said I have to hold fown the button to keep it going. Any insights or things to check would be greatly appreciated
    Jul 2005
    Cottage Grove, MN 55016
    7,973
    4247
    4719
    J&S Valve in Oklahoma bought a Kent Grinder also made in Taiwan and I was there and used the grinder and I could not get the cross feed to work, could get the table feed to work when I pressed the feed button. Then one of the machinists showed me I had to press the feed button 2 times to get the cross feed to work. Seemed weird but it worked. Give that a try.
    Jul 2019
    Thanks will give that a try.
    Nov 2010
    netherlands
    86
    30
    Hi,
    Think it could also be a faulty relay.
    If you have two of the same type in the machine try swapping them and see if the problem moves.
    Greetings Peter
    Verzonden vanaf mijn iPhone met Tapatalk
