Anybody familiar with Drukov grinder?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
    Mar 2005
    Indiana
    5,712
    1900
    1851
    Default Anybody familiar with Drukov grinder?
    I just picked up a nice little tool post grinder locally, has ID and OD spindles, a well as a tiny little taper in the end of the O.D. spindle that takes miniature adapters for itty-bitty I.D. grinding. Never heard of the brand but it appears to be pretty well made. Google seems to show that a few have been auctioned but no real info other than that. Says Brno, so I'm guessing it's Czech in origin. Anybody used one? Worth hanging onto?
  2. Likes michiganbuck liked this post
  3. #2
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,553
    2703
    1641
    Sorry, no info to add. Curious, pic 3 of extra spindle, left side, what is the gear section for? And looks like numbers on collar?
    Edit: I'd hang onto to it, but then again I have too much stuff.
    Virginia
    17,989
    7561
    11409
    Quote Originally Posted by eKretz View Post
    "Guess"? You should visit!
    Moravian, if you want to get fussy. Present-day, the name b'long a boilermaking firm!
    DRUKOV Brno - Produkty
    I'd bet that the arms maker, CZ or the machine-tool builder, ToS, would know something about the grinder. They'd have been likely users, times gone by.
    Both have staff superbly competent in English.
    Mar 2005
    Indiana
    5,712
    1900
    1851
    The geared section mates with a worm connected to the round aluminum handle on top. I think it's eccentric - the handle has graduations in 0.01 mm (~0.0004"). Must be for finishing so you don't have to use lathe cross slide or turn the compound way over to get fine infeed. No idea about the graduations by the wheel end of the spindle yet. No manual, so gotta play it by ear and figure it out as I go.
  6. Likes dalmatiangirl61 liked this post
  7. #5
    Virginia
    17,989
    7561
    11409
    The language is sorta-kinda-partially readable as-is, but translates VERY well with google. A manual may exist.
    From the present-day Drukov website:
    History
    The company was founded on September 19, 1949 as a metalworking cooperative DRUKOV with facilities in Brno and the surrounding area with a wide range of activities. The main production program of the facility at Cejl 18 in Brno has always been the production and installation of thermal technology.
    They were struggling, post WWII. Skilled folks, and desperate at looking for ways to earn a crust. Thermal was in demand. But I wouldn't rule-out it was the same "Co-Op", back in the day as also made that grinder.
  8. Likes eKretz liked this post
  9. #6
    Mar 2005
    Indiana
    5,712
    1900
    1851
    I found a pdf manual but, as is often the case with technical language, it does not Google translate well. I gleaned a little bit, but mostly it was gibberish in the sections I was actually interested in.
  10. #7
    Jun 2012
    Michigan
    13,118
    4452
    4736
    I would run all spindles slow for time to give decent warm-up to loosen grease rather than sling chunks. look for Oil fill holes.
    looks like a decent grinder. A miny abrasive wheel dresser can be good for sich a grinder.
    Wow, I can't find a crackerjack mini for sale, here is a wheel.
    Desmond Mini Crackerjack Dressing Wheel Item Code 25520 Max RPM 16555 | eBay
    Desmond - Grinding Wheel Dressers - Crackerjack Dressers
  11. Likes eKretz liked this post
  12. #8
    Dec 2002
    Benicia California USA
    8,671
    2227
    3062
    looking at the photos. Looks like the drive motor is rigidly mounted, unlike a Dumore that has a hinge.
    Wondering if the eccentric setup is there to tension the drive belt.
    Cheers Ross
  13. #9
    Mar 2005
    Indiana
    5,712
    1900
    1851
    No, the drive motor is mounted on a flange that slides in a slotted fit to tension the belt while keeping the pulleys in alignment. I just spent a few minutes playing with the grinder and the eccentric is definitely for adjusting the depth of cut/size. The aluminum knob has a collar that can be twisted to zero it out that is graduated in 0.01mm increments in diameter, so turning by 1 increment would change diameter by about 0.0004". They're pretty widely spaced so easy to hit sizes in between. I stuck an indicator on the front of the grinding wheel collar, and it turns out the numbers on the spindle itself are increments of 0.1mm in diameter. So every full turn of the aluminum knob rotates and changes the increment on the spindle by 0.1mm in diameter, or actual movement of a little under .002". Pretty cool setup. Definitely a keeper.
    The large red screw is a cap that covers another screw in the spindle which from what I can tell with Google translation of the manual is for adding/checking oil. There are two smaller flat-bottom screws that clamp the spindle cartridge eccentric rotation (not the actual rotating while grinding part attached to the wheel), one of which is visible lower than and to the right of the red cap screw.
  14. Likes dalmatiangirl61, michiganbuck liked this post
  15. #10
    Feb 2010
    ch
    2,980
    247
    402
    if you have specific questions you can mail me the manual. my grandmother was moravian, i might figure out what is says.
  16. Likes eKretz liked this post
  17. #11
    Mar 2005
    Indiana
    5,712
    1900
    1851
    Thanks for offering. It's not very long, you can download it here:
    Dropbox - SBMT-2.pdf - Simplify your life
    Can't do attachments through the PM email feature.
  18. #12
    Feb 2010
    ch
    2,980
    247
    402
    so bearings are spring preloaded. for inside grinding dress the stone convex by hand. otherwise there is not much.
    do you need to know anything in particular? they mention an addapter for grinding cylinders, no idea what that is.
  19. #13
    Mar 2005
    Indiana
    5,712
    1900
    1851
    Yeah I managed to get that part about convexing the wheel for ID grinding from Google translate, not sure what they would want you to do that for other than reducing area of the wheel in contact at once.
    I saw a little about that "adapter for grinding cylinders" too - made about as much sense to me as it did you. I would think a toolpost grinder is generally already for grinding cylinders... perhaps that is referring to the second spindle cartridge I've got for deep cylindrical I.D. grinding.
  20. #14
    Feb 2010
    ch
    2,980
    247
    402
    i believe thy say to change the spindle for "cylindrical" grinding. so you have another spindle? maybe its a long one taking larger wheels? interestingly they also talk about "surface grinding" with a saucer wheel. how would you do that?
    btw, how did you find the manual?
  21. #15
    Virginia
    17,989
    7561
    11409
    Quote Originally Posted by dian View Post
    Mount it to a planer or mill, rather than a lathe. CAN work better than it sounds with skilled fiddling, and has to do, if resources are slender.
    Some optimists have even used shapers, droop and all, and "made it work, well ENOUGH" to get a problem sorted even when the grinder was an ignorant ANGLE grinder!
    I kid you not. Shaper and angle grinder. Photos are on PM, somewhere.
    You'd have to know clever humans and desperate times?
    "Run what you got!"
  22. #16
    Mar 2005
    Indiana
    5,712
    1900
    1851
    Yes the second spindle cartridge is visible in the third photo in my first post. It is long, I figured it was for deeper ID grinding. I suppose it could be used for OD work also, but not sure what advantage that would offer over the regular OD spindle. I suppose surface grinding would also be possible in the lathe with a cup wheel and a method to index the spindle. One could probably sharpen the ends of milling cutters too I suppose. Not something I'd really want to do, but if necessity arose...
    I found the manual with Google. Took a little searching but it turned up eventually.
  23. #17
    Dec 2008
    LANGLEY, WA
    20
    6
    Default Drukov Toolpost Grinder
    These are similar to Grizzly T27400, but the latter seems to be updated to B&S taper hubs and 1-1/4" ID for larger wheels (versus 2.0" ID for Drukov). I just put my Drukov up on ebay, since I no longer have a use for it. Thanks for posting the Manual pdf.
  24. #18
    Mar 2005
    Indiana
    5,712
    1900
    1851
    You're welcome. I rather hope that it's of considerably better quality than the Grizzly... I've had it apart a bit and it looks pretty nice. Good fits and smooth functioning. It has a 3-phase drive motor, I'll run it off a spare vfd when I finally get around to getting it up and running.
  25. #19
    Dec 2008
    LANGLEY, WA
    20
    6
    The photo you posted shows a start capacitor, so I doubt it's 3-phase.
  26. #20
    Mar 2005
    Indiana
    5,712
    1900
    1851
    Quote Originally Posted by optoeng View Post
    It most certainly does not...
