Anyone know anything about Norton hydraulic surface grinders?
Results 1 to 8 of 8
    Aug 2017
    Florida
    44
    Default Anyone know anything about Norton hydraulic surface grinders?
    I have a 6x18 Norton hydraulic grinder and I just had a few questions about it concerning the hydraulics and cant seem to find much info on them elsewhere. Anytime I run the hydraulic table and cross feed it jerks alot when changing directions. Right now the machine is resting on two 4x4 steel square tubes so we can move it with a forklift if necessary (this is my personal machine, the shop I work at just lets me keep it there, but occasionally they need to move things and there really isnt any way to move this thing easily if its sitting on the ground). I understand that its best to keep these things bolted down but until I figure out a way to put it on the ground so it can be moved if needed this is all I can do. Also It makes a strange sucking sound when it changes direction and I dont know if thats normal or if theres an issue somewhere. Any insight would be greatly appreciated!
    Jul 2004
    Houston, TX USA
    30,900
    Sounds like air
    it jerks a lot when changing directions
    Here is the "suspended" hyd pump in the WW2 version - one assumes it is "suspended" in the hyd. fluid reservoir - which seems to be low on oil if its making 'sucking" noises (actually, this is for an OD grinder - don't know what the SG used)
    Hyd. systems work best when there is all fluid and zero entrained air
  3. Likes eKretz liked this post
    Aug 2017
    Florida
    44
    Quote Originally Posted by johnoder View Post
    Sounds like air
    ill check that, but im pretty sure its full. Could there be air in the system that needs to be purged?
    Mar 2006
    jacksonville,fl.
    1,278
    1134
    429
    The cylinders have enough volume moving during use to self purge.If the pump is not a submerged unit,some types will suck air around the shaft seal when they harden or wear.It is a low pressure area when the pump is running so will not leak oil.Easy way to check is to squirt some oil around seal while running and hear if the sound changes.Also look into the tank after it has run for awhile and see if the oil looks milky.If so then it is air emulsified ,after it sits for awhile not running then it will clear up.Not all pumps will do that but those that do it is a common problem.
  6. Likes Paolo_MD liked this post
  7. #5
    Feb 2010
    ch
    2,500
    215
    329
    the hydraulics can also suck in air on the high pressure side. i never understood how thats possible, but mine did.
  8. #6
    Apr 2018
    4,279
    1935
    Air makes them jerk like that. With a Heald I'd always run the table all the way back and forth several times when starting it to get the air out. Same with Landis, run the head in and out and the table back and forth all the way to the ends of travel if possible. Air comes out of solution, leaks around the rod seals, gets into the cylinders in many ways when they go to sleep.
    Also levelling the machine helps somewhat, they are designed to have air go out the high spots when the machine is level.
    @dian - maybe cavitation in the pump ? Get little bubbles entrained in the fluid, then they collect into one larger bubble at the ends of the cylinders ?
  9. #7
    Feb 2010
    ch
    2,500
    215
    329
    no, it was a seal on the high pressure side of the pump.
  10. #8
    Jul 2005
    Cottage Grove, MN 55016
    7,874
    4204
    4676
    I found this on the net. It shows how to set the hydraulic system reverse valve .
    http://www.chasgallen.com//wp-conten...ors-Manual.pdf
