HowHardCanItBe
- Oct 20, 2014
Thanks to all who post here. What a treasure!
I recently discovered that a Brown & Sharpe No. 5 8x24 Precision Grinder at our makerspace (Cincinnati's Makerspace) is missing 6 parts from the return flow path of hydraulic fluid (circled in red in the attached picture of parts). These parts, when present, are located in the top of the machine's base. I've volunteered to remedy this situation. We have local high school robotics club students using the space to build their robots, and we want to return this to service ASAP.
Which way does the fluid flow through pipe 23-2810? a) does fluid enter at the top of the pipe and exit at the notch towards the bottom (prior to being filtered), which means the bottom of the pipe would need to be sealed, or
b) is the top sealed, directing fluid outside the filter, and fluid first enters the pipe at the notch (after being filtered), and exits out the bottom, or
c) am I completely lost?
The Operations and Maintenance Manual I recently found mentions that a clogged filter will cause overflow, which I presume means flow out over the top of the cartridge (above the J slots, see attached pictures). This would seem to indicate that fluid passes through the filter from outside to inside (case "b" above), with only the hydraulic head provided by the height of the fluid in the cartridge (<7", since open to atmosphere) pushing the fluid through the filter? I think this oil is already returning at atmospheric pressure, after lubricating the table ways, and is being filtered to trap contaminants from same, prior to discharging into the base.
Thanks in advance, and stop by if you're ever in northern Cincinnati, Ohio.
