M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
I'm looking for a mag vise similar to this one to go on our 8"x20" surface grinder.
Hishiko Corporation:Tilting Permanent Magnetic Chuck
We do a number of ground angles (mostly straight edge blades with bolt holes and slots) which typically involve custom fixtures, or clamping the piece to a T-slot tilting table. I've seen the mag chucks that hinge on one side, but having the trunnion type like above seems like it would be faster to set and more ridged. So far I've only found them coming out of Asian supply companies. Anyone know of something more local? I wouldn't be against used also.
I first considered building a trunnion that a standard mag table could mount too that could work like a 4-axis or horizontal rotary table, but head-space would be an issue.
