engiNERD77
- Apr 17, 2014
- Prairie du Sac, WI
Can anyone give me some reasonable expectations for Blanchard ground tolerances for plate aluminum and steel? Thanks.
flatness and parallelism?
Is that number mm or inches?+/- .003 and f&p .003 is our standard callout
.Can anyone give me some reasonable expectations for Blanchard ground tolerances for plate aluminum and steel? Thanks.
on a 8" x 17" plate of aluminum I would expect to see you use up the entire tolerance of flat and parallel .003"
If you cannot Blanchard grind a small piece of aluminum like that in 7075 or Mic 6 within +/- .001 your doing it wrong.
Start with low-stress plate, like MIC6 or other cast plate. Machine the plate oversize. Run it through a couple of (plastic part) annealing cycles without any plastic parts. Remachine/grind the plate to final dimensions. Should be pretty stable through subsequent annealing cycles.
No idea about thickness. How will the plate be supported in the annealing oven? That probably is relevant to the question of how thick to make it.
Notice
