JimHilliard
- Jan 4, 2009
- Mendon Mi.
Good morning all, I am looking for help on a 1982-1984 Boyar Schultz grinder. After disassembling , cleaning , painting and reassembling the machine. I can not get the hydraulics to respond correctly. The table will feed left to right and right to left but the speed can not be adjusted (slower or faster) the front to rear axis works fine (full travel and speed is controllable in dress mode as well as feed mode)When I adjust the cushion , if I go too far the table blows past the directional shift lever till the cylinder strokes out. I have replaced all seals , o rings , and gaskets. I also checked the spools for fit and finish and they are good. I called W A Whitney in Rockford Ill. with out any success. They have no one to support the grinders and their parts inventory is very minimal. Without part numbers they can't help at all. I am hoping to find someone with expertise on the hydraulic system . Thank you....Jim
