Boyar Schultz 612 - Dating By Serial Number? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
  1. #41
    Oct 2019
    5
    Thanks Ballen! I made this block to hold the diamond I found on fleabay. I think I'll chop off an inch, it's a little long. Looks like I'm on the right road! I'm going to replace the belt in it, It's stiff as a board.
  2. #42
    Feb 2012
    South Jersey, USA
    39
    10
    Hi guys, this seems to be the vintage # place. I picked up a 612 with a # of 18890 on top of a dust collector with a #4165. Any Idea's on the Mfg dates? Thanks in advance.image1-611-.jpgimage0-610-.jpg
  3. #43
    GERMANY
    3,677
    2465
    1486
    Quote Originally Posted by Jagboy69 View Post
    Looks good! Yes, shorten the diamond holder until just a bit projects out. You want it as rigid and vibration free as possible.
    Dress with the diamond tip directly under the grinding wheel spindle axis. Don't dawdle, traverse across the diamond at a good clip. Take off at most 0.001" per dressing pass. Don't make a second pass with the same height setting. If you have coolant, run it while dressing. (Diamond is made of carbon and during dry dressing, the tip will turn red or white hot. You don't want to burn away the diamond too fast!
  4. #44
    Feb 2012
    South Jersey, USA
    39
    10
    The restoration has begun...
