That procedure is a must for grinding graphite EDM electrodes.. Otherwise you get deep scratches. I usually use a piece of .005 or .007 shim stock to lightly touch the wheelThe diamond tends to tear the grit out, rather then cleanly shearing it off.
It's worth holding a bit of wood or similar to the wheel before the first cut, just to knock off any loosly held particles that might otherwise cause scratches.
well, the ratio of fractured particles will depend on grit size to dressing deph, hardness of wheel and other parmeters. if you slowly dress a 46 wheel going 0.01 mm deep, you fracture most of the grains and the wheel woud benefit from opening up. as far as i can tell, nobody does it, though.
Notice
