Boyar Schultz 612 Spindle Rebuild - Page 2
Results 21 to 40 of 42
  1. #21
    Jul 2001
    North Carolina
    1,844
    128
    335
    Very nice. I have the same Boyar Shultz belt drive grinder and I have done the spindle bearings some years ago. I do remember mine had loose balls, like bicycle head bearings. I did not have Kluber grease back then. Only Kendall blue wheel bearing grease. No trouble with the bearings yet. Guess it was a success. One other mod that I did was convert the table and the column to one shot pump oiling.
    --Doozer
  2. #22
    Apr 2010
    Ohio, USA
    I know this is an old thread, but...
    I just got one of these beasts myself. Spindle is noisy. RLamparter: this is one amazing writeup! Thanks a ton!
    Quick question: if I just want to try cleaning/relubing bearings, is it necessary to remove them from the spindle?
    Wallace
  3. #23
    May 2009
    Canandaigua, NY, USA
    2,507
    107
    968
    Yes, there's no other way to get at them. IMO, the old grease will be hard enough that some scrubbing, brushing or pokeing with a soft stick can be necessary.
  4. #24
    Oct 2008
    Central PA
    545
    31
    Yup. Conrad's right. There's no way to get to the bearings without removing the spindle.
  5. #25
    May 2009
    2,507
    107
    968
    Don't underestimate these old girls. Mine is about as old as I am, and the bearings weren't exactly shiny when I cleaned and regreased them. Did a good cleaning of the important stuff, but didn't have time to strip and paint it. It's seriously ugly, probably painted with latex by a house painter. Added a VFD. Ground some pieces and brought them to work to check on much fancier equipment than I've got. The thing still grinds a 2.5" diameter puck to sub-micron flatness in both directions, and longer pieces seem OK too.
    I'm a bit baffled by the fact that when grinding is involved, everybody thinks the cost has to go up by 10X. If the parts are designed right, and not too much is left to clean up, grinding is the easiest job in the shop.
    One hint- they work way better if you have some way to balance the wheels.
  6. Likes stephen thomas liked this post
  7. #26
    Aug 2013
    IL USA
    10
    Quote Originally Posted by Conrad Hoffman View Post
    Where do you find an accurate tapered rod to hold the wheel and arbor for balancing?
  8. #27
    Apr 2010
    Ohio, USA
    This one ended up being a "shake your head in wonder" story...
    Got spindle housing off - heard something rattling around inside. Got things apart. Someone had already replaced bearings, but hadn't tightened retaining nuts nor bent keeper tabs to hold them. Inner nut and keeper were sliding around on the spindle. Rear was hand tight. No grease on bearings. Sigh.
    Luckily, the bearings looked great! Front bearing was:
    https://www.motionindustries.com/pro...p?sku=00114155
    Rear looked like same brand, but couldn't find it. The cheapest I found that front bearing was $570!!! Someone paid >$1000 for bearings and then let the shop idiot reassemble the grinder!
    Anyway, cleaned all carefully, put 2 cc's of Chevron SRI-2 in each, and reassembled. Grinds way better than before (no surprise) but still a little noisier than I'd think it should be. But, it seems pretty solid and will be more than up to any hobby-type grinding jobs I'll ever have.
    Thanks again for the help folks!
    Regards,
    Wally
  9. #28
    May 2009
    2,507
    107
    968
    Quote Originally Posted by meowkat View Post
    I don't. I just stick an accelerometer on the chuck and do a 4-run single plane balance. It's pretty fast and easy- spreadsheet on my website will work out the weight and location of the final weight from the four trial runs with an arbitrary weight.
    On the bearings, SRI sounds like a good choice. Good for high speeds and should last near the life of the bearing. I have that, but used a Kluber because it was also on the shelf.
  10. #29
    Aug 2013
    CT
    37
    excellent thread, thank you. I have a 612 that is noisy so this will help if I get to working on it. Very glad to see the pictures are still up too.
  11. #30
    Feb 2010
    ch
    2,045
    187
    267
    conrad, what exactly do you stick on there?
  12. #31
    Mar 2018
    Connecticut
    I have just joined this forum and I have a BS 612. I purchased it several years ago and have just powered it up and of course the bearings are howling..... rather than have a failure I am going to disassemble and inspect or replace the bearings, so finding your series of posts of your rebuild was just fantastic. You had mentioned that pictures were available and I am wondering if they are still available? If so would it possible to send them to my email account?
    On another note do you or anyone know of a list that might help identify the age of these bs 612's?
    THANKS FOR YOUR FANTASTIC POSTS!!!!!
  13. #32
    Oct 2008
    Central PA
    545
    31
    I haven't re-read the entire post, but after emailing you I noted that all of the photos for the sequence were present above. If you click on a thumbnail, it will show up as a full size picture. Are the full sized photos what you were looking for?
  14. #33
    Jun 2012
    Michigan
    8,611
    2558
    2922
    Great thread ..I don't have time to read it all today but will come back..few things I hope you mentioned..line up bearing marks/never blow bearings to a high spin RPM with air but hold and blow out is fine and the nose error is not that important because a light grind after rebuild will fix that.
    Oh and grease perhaps 1/4 to 1/3 filled...
    Will come back next week and read it closely..
    .00025 not bad for a used spindle nose...
    Oh and if one picks up a setting-long grinder..hand spin the spindle many times to set lose stuck grease and some may be ok to good..full speed may slide one stuck ball and ruin a bearing.
  15. #34
    Mar 2018
    Connecticut
    Quote Originally Posted by RLamparter View Post
    yes that is exactly what I had hoped for....however if I can use the existing photos I will do so....THANKS for the quick reply
  16. #35
    Oct 2008
    Central PA
    545
    31
    I thought it would be a good idea to comment that the bearings in my machine were Bardens and my serial number is around 11,500. Elsewhere on the internet I found that in some earlier machines Boyar Schultz used Fafnir MM 205 WI bearings as seen in the photos below. I *think* I read somewhere that these are the same bearings used in the spindles of Bridgeport milling machines and that they're less expensive than the Barden equivalent.
    85-fafnir-mm-250wi-front-bearing-large-.jpg 86-fafnir-mm-250wi-front-bearing-opposite-side-large-.jpg
  17. #36
    May 2009
    2,507
    107
    968
    Quote Originally Posted by dian View Post
    If I told you the exact p/n it wouldn't help, as I've been scarfing up surplus electronics for a long time. I think it's a Wilcoxon seismic accelerometer that probably cost a fortune. Most anything will do, but you have to filter it. I use an ancient General Radio vibration analyzer that has a notch filter. At 3600 rpm, that's 60 Hz. Without a filter you see too much noise. If I didn't have anything, I'd buy a cheap MEMS chip accelerometer and make a simple one or two opamp filter.
    FWIW, I bought one of the expensive Norton SG wheels. They're quite dense and no amount of dressing or fiddling would give me a good finish. Only when balanced was it remotely useful for anything. OTOH, I just got some thin 3/16" white wheels and they don't require anything at all other than a proper dressing.
    My machine is a bit noisy, but it doesn't show on surface finish. I think it's something to do with the front dust trap or maybe the weird EDMd coupling mine has. It doesn't use the usual rubber type.
    When the weather gets warmer I need to make a new in-out lead screw. Mine's worn to heck!
  18. Likes Milland liked this post
  19. #37
    Jan 2018
    Illinois
    I just purchased a 612 2A. After getting it in the garage shop, setting it up, dialing it in and setting up my first part. I turned it on and the spindle makes a horrific noise then quiets down to a normal hum. Would this be indicative of a spindle rebuild/ new bearings? If so, where would one source these bearings? Thanks in advance!
  20. #38
    May 2009
    2,507
    107
    968
    Don't do that! Maybe the lube is just dried up and/or the preload isn't working- it's spring loaded and could bind up. You need to take it apart and clean/check/lube the bearings. Might need new ones, but just as possible you don't.
  21. #39
    GERMANY
    1,914
    935
    579
    Quote Originally Posted by ProbleMattic View Post
    I don't know anything about this brand/model. But could the horrific noise be a drive belt slipping as the grinding wheel comes up to speed? Then once the wheel has spun up, the belt stops slipping and the horrific noise stops.
  22. Likes Paolo_MD liked this post
  23. #40
    Jul 2005
    Cottage Grove, MN 55016
    6,480
    3464
    3835
    Go buy a mechanics stethoscope and lisen where the noise comes from. If the bearings are bad, turn on the spindle and shut it off and listen then ad that is when you hear it worse. A low graveling grawl....many machines used a coupling with a rubber cushion and on old machines they break and that might be the issue.
