Hello, was looking at possibly purchasing a B&S surface grinder, they are reputed to be a good, if smaller grinding machine. Doing a little research, it appears that they've had a few lines along the way, 618's, 818's, series I and II, models that end with a PH. Does anyone have some thoughts on these, and the differences between the models? One thing I came across is the Series I has a cast base, and the series II is welded. No idea what the PH stands for though, which I saw when looking at the repro manuals available on Fleabay.
With some models of manual lathes, it is known that often times the older models are 'better' than later produced ones, I was wondering if the same thing held true for this brand and machine type, or have technological improvements from the 60's to the I guess 90's(?) when these were made make the later models actually more desirable? Anyone who has knowledge or even thoughts on this are encourage to chime in.
