Cincinnati 2u Universal Grinder help.
Results 1 to 7 of 7
    Jan 2009
    Carrollton,Ohio(east central), USA
    101
    Default Cincinnati 2u Universal Grinder help.
    [ATTACH=CONFIG]217989
    Does anyone have a parts diagram of the coolant pump for this machine? I need to remove it and not sure if I have to unbolt it from the bottom mount at the pump or just remove the motor on top. Will I loose fluid or is that a dry connection at the pump? Thanks,Darrel
    Sep 2005
    Oakland, CA
    2,069
    104
    501
    Doubt you can pull just the motor unless there is a hole in the housing under the motor to disconnect the impeller shaft . You have to pull it by removing the bolts around the lower flange. That's not a dry connection if I remember correctly- you better plan on draining your coolant before removing the pump or you might well have a big surprise on your hands.
    Jan 2009
    101
    Thanks Dan. I had that off a long time ago but can't remember what it took. I guess I'll get the barrel and pump ready.
    Jan 2009
    101
    Update- There is no shaft seal on this one. Just length of the shaft keeps the solution separated from the motor. There is a nut on the bottom of the impeller and the shaft housing slides off from the impeller end. I indeed had to drain some of the grinding fluid to take the pump housing.
    Jul 2004
    Houston, TX USA
    27,530
    The 1P says 1944
    Jan 2009
    101
    Thanks John. Good to know. I dropped the pump motor off today at the motor shop and they think it will be quit pricey to rewind. I wanted to sell the grinder but this may change things. Thanks again, Darrel
    Sep 2005
    Oakland, CA
    2,069
    104
    501
    Yea, it kinda looked like the motor was above the coolant level- that way no shaft seal is needed. Nothin is ever simple!
