cleaning a new surface grinder
Results 1 to 8 of 8
    May 2012
    ON, CANADA
    20
    9
    Default cleaning a new surface grinder
    what is the best way too keep a new surface grinder lasting ?(80 by 40 inch table) squeegee the table/ wipe dry /
    WD-40 table/ park the wheel in centre of table and high up/ok to clean off coolant with air line?
    thanks
    Apr 2019
    South Carolina
    6
    You pretty much hit the nail on the head. I've been at shops that run equipment from the 90's that look great because they wipe down the machines after every shift. Depending on the parts you're grinding make sure to use a coolant that will produce an acceptable part and NOT eat away the paint / exposed metal. Also make sure to use the correct ratio! Congrats on the new grinder, what did you end up getting?
    - Erik
    Sep 2005
    Oakland, CA
    2,311
    197
    599
    Dump the airhose idea! Blowing crap into places that its not welcome has ruined more machines than I care to think about.
  4. Likes Larry Dickman, Rewt, cash, tdmidget liked this post
    May 2012
    ON, CANADA
    20
    9
    Kent :alum/tool steels/mild steel grind
    ing
    May 2012
    ON, CANADA
    20
    9
    thought that , just wipe down/ as best we can/after a clean with coolant spray
    Jun 2006
    Near Seattle
    4,602
    2796
    1201
    i find that the right brushes (stiff nylon or SOFT brass) are helpful on mills, likely on SG as well
    Sep 2015
    Tennessee
    453
    234
    348
    Quote Originally Posted by Dan from Oakland View Post
    Also buy you a rubber squeegee for the chuck, then wipe down with shop rags. Our shop SOP means you have to open up the stone guard and clean inside there too.
  9. #8
    Aug 2007
    Wisconsin
    2,051
    1053
    897
    Clean coolant, wipe down daily with shop rag.
    Keep your machine clean/oiled and it will keep you busy!
    Good surface grinders are hard to find!
