PackardV8
Hot Rolled
- Jun 4, 2006
- Spokane, WA
Greetings,
We are an obsolete engine shop and one of the services is regrinding valve tappets on an old Tobin Arp tappet grinder.
The standard grinding wheel is a 1.25" center hole 6" stone cup. These have to be continually redressed and wear quickly and heat the workpiece.
We decided to try some diamond impregnated face aluminum wheels. Since this was a test, we went with the $35 eBay Chicom wheels. The 320-grit gave a nice finish but cut too slowly. Next, we tried a 280-grit. The initial finish was not acceptable, but we ran several sacrificial lifters through it and got better results as it wore in. After about 200 lifters, it doesn't cut any longer. A nice side benefit of the diamond wheel is parts come out cool.
Going throught the catalogs, it's possible to pay as little as $21 and as much as $600 for the same size and grit wheel.
What guidance can you give us as to the sweet spot for a wheel which will produce finished parts from the first.
jack vines
jack vines
