Delta Milwaukee Surface Grinder Rebuild Questions
Results 1 to 6 of 6
    Feb 2011
    2,571
    2113
    1142
    Default Delta Milwaukee Surface Grinder Rebuild Questions
    I picked up a "free" surface grinder a few weeks ago. I was buying a different machine and the guy had a pile of parts that was going to go to the scrap yard. It looked like it was all there, so I decided to take a stab at it.
    It's an old Delta Milwaukee surface grinder. I don't think it's the "Toolmaker" version as it doesn't have any of the table taper features or tooling. Once I got it all sorted out, I found it was missing some simple stuff, but otherwise could be a functional grinder again. I decided to take it on mainly as practice scraping. The ways aren't too bad, but they're all simple flat ways so it's going quickly.
    So my questions are about the motor/spindle set-up. It was missing the OEM motor and pulleys. I have another 1/2 HP sealed frame 110v Delta/Rockwell motor that would fit nicely with the machine, but I've also read that the spindle and motor need to be dynamically balanced. Is that something only the pro's can do or where would I start?
    I was able to find an OEM spindle pulley (2 speed), but am still missing the motor pulley. Short term, I'm thinking I'll use a single groove pulley and pick a speed, but to replace the 2 speed motor pulley, I think I'll need to make one. Can someone measure the diameters of the steps for me? Otherwise I can do some math and figure approximate diameters, but the original dimensions would help.
    I'm thinking about putting it together with what I have and taking some test cuts. If I get a lot of chatter, then I'll know that it needs balancing.
    As a side note: I'm fairly certain this machine was a Hurricane Harvey victim. Random places have been full of water, but 90% of the machine is rust free thanks to it not being kept very clean of grease and grime. The other 10% of exposed surfaces were heavily pitted. This included some areas of the spindle, but thankfully all of the bearing seats and the front taper bearing are damage free. But perhaps the pitting will have a play in how balanced the spindle is now.
    Jul 2006
    Cumberland, Maine
    478
    68
    106
    It's the grinder itself that carries the "Toolmaker" name, whether or not it has the optional swivel table, centers, Unihead, etc. The Vintage Machinery website has most of the available literature, or you can find a bound copy on eBay.
    Mine has the OEM motor, but a replacement single groove pulley. I doubt that they were balanced together. Would I get a better finish with a balanced setup? Probably, but it is good enough for most of what I do. A good motor shop should be able to handle the balancing. Delta says the motor pulley was 5-15/32" diameter - large step, I assume - and shows speeds of 3200 and 4200 RPM with a 1725 RPM motor. As you have an original spindle pulley, the math should be easy. My motor pulley is 5". Not sure why they had the two speeds, presume it was either to keep larger wheels under their rated max, or maybe to allow you to tweak for the best finish.
    I did see an original motor pulley on eBay recently, but with a 1/2" bore. My motor is 5/8". Delta shows 1/2" in a 1956 catalog, I think mine may be older.
    There is a newsgroup just for this machine. It's a Yahoo group, but not very active.
  3. Likes M.B. Naegle liked this post
    Jan 2002
    West Coast, USA
    8,716
    582
    6209
    My understanding is that the motor and pulley were balanced together.
    Since you're starting from scratch, you might consider getting a decent (good bearings) 3 phase motor and a VFD (cheap for under 1hp). Could be handy. I suspect you could sort-of static balance the motor and pulley by seeing where it stopped. If it always stops one place down, you might lighten drill the pulley there to get it a bit closer to balanced?
    These use a non-standard wheel adapter. If yours came with more than one, count yourself lucky. None? Last I looked replacements were around $150.
    Feb 2011
    2,571
    2113
    1142
    I've got one hub for 3/4"+ wheels, It would be handy to have a smaller one for 3/8"-1/2" wheels. I've been wanting to buy a wheel balancer for our shop, but in general I try to keep hubs and wheels (on our other surface grinders) together once they're running well.
    Jun 2020
    Wisconsin
    I just bought a Toolmaker grinder, in pieces. It is heavy so I would like some info before I start making dunnage to prop this thing up prior to reassembly.
    Specifically, what is the spacing between the floor bolt holes between the individual sides of the pedestal legs. Its heavy, and I'd like to know where to drill the anchor bolt holes so I can bolt the legs in place before I set the pedestal on the legs.
    Feb 2011
    2,571
    2113
    1142
    Quote Originally Posted by gargoyle169 View Post
    Delta Manufacturing Co. - Publication Reprints - Toolmakers Surface Grinder Brochure | VintageMachinery.org
    Doesn't look like those dimensions are in the manual, but I'd suspect that they'll be different machine to machine since there's no bottom brace to set the bottom width of the legs. If you just need some way to hold the legs upright, I'd use some lumber to hold them up while you get the top in place, or bolt it together laying down and then lift the assembly upright. These machines are not supposed to put out a lot of vibration and given their small caliber size, they're handy to move around, so I wouldn't bolt it down unless you were worried about forklift operators bumping into it.
