Disk Sander VFD Suggestions
Results 1 to 7 of 7
    Jul 2018
    20
    Default Disk Sander VFD Suggestions
    I recently acquired a disk sander and I知 looking to run a VFD to achieve single to 3 phase. I currently have a rotary converter but I知 tired of listening to it run all the time. The sander has a 2hp GE motor. What could be a quality but cost effective VFD? My understanding is it needs to be rated for double the size of the motor? Thanks for the help!
    Dec 2003
    Washington
    4,842
    2369
    4366
    Control-Techniques p/n M200-02200075A . . . we buy them for under $250 and they are rock solid and easy to set up with top of the line documentation compared to the crappy Chinese drives.
    https://acim.nidec.com/drives/contro....ashx?la=en-us
    Jul 2018
    20
    Quote Originally Posted by motion guru View Post
    Thank you for your reply! The 075 p/n shows for a 2hp, is the rumor to double the VFD size in relation to the motor size not needed? Where are you sourcing the Control Techniques drives from? Not much in the US is showing up when I search the p/n.
    Apr 2013
    Damascus, MD
    1,515
    4446
    861
    You need to oversize (i.e. de-rate) only VFDs made to take only 3-phase input, sun on single phase, since you would channel the input current on only 2/3 of the original input.
    I hope it makes sense.
    Paolo
  5. Likes eKretz liked this post
    Jul 2018
    New Hampshire
    67
    12
    VFD's are a complicated subject. Many lower power ( 2HP or less) are designed
    to run off single phase. If so they may give full rated power even running
    from single phase, check the specs. I have some 10 HP VFD's that are single
    phase capable but must be de-rated to 5 HP (it's in the spec's).
    In your case with a sander you have a better situation. A VFD running a pump
    may run at full power all of the time so power limits should be checked carefully.
    Your sander probably uses a fraction of the full power most of the time. Starting
    is probably very easy for a sander, no heavy load. This is an easy job for a VFD.
    VFD's have circuitry watching the load current all of the time. If you cause an
    overload it will shut down without harm. You could probably use a 1 HP VFD with
    no problems. When you use your sander and exceed the 1 HP limit it will just
    shut down, no harm done.
    So, you could probably buy a 2 HP unit and not worry about de-rating it. The
    2/3 number comes from a simple calculation relating to rotary converters and does
    not necessarily apply to VFD's (check your spec's).
    I run 2 HP machines off 2 HP VFD's without problems. They are mills, lathes,
    and surface grinders. All machines that don't use their full power unless
    I do really heavy work. When I exceed their limit they shut down, no problem.
    They really are an ideal solution. Just remember, no switches or fuses between
    the motor and the VFD.
    Mostly, check the spec's.
    Dec 2003
    Washington
    4,842
    2369
    4366
    Quote Originally Posted by Perry42985 View Post
    They thought of that with this drive option . . . designed for single phase input - 3 phase output - I clipped this from the PDF linked in my original post. We are well over 3000 CT drives sold in the last 25 years and they are great drives for this kind of application.
    They have a slightly lower end drive that would probably work fine, and I just realized that this drive was recently discontinued but still available from many sellers - p/n - M100-02200075A10101AB100 . . . lists for about $320
    Add a speed pot for $10 and the part number changes to M101-02200075A10101AB100
    The replacement drive is an upgraded version of their Commander Series . . . C200-02200075A10101AB100 . . . lists for about the same
    The M20x series has communications options if you want to configure with their free software - M201-02200075A10101AB100 with a list price of $410 . . .
    We have a factory account - if it were me, I'd just use the M101 if you can find one and use the Speed pot when you wanted to adjust your sander speed. PM me if you can't find a local stocking distributor. They rarely charge full list for something like this.
    Aug 2006
    North Carolina
    112
    17
    9
    I'd get a 3hp unit, just a little more expensive,and you can run additional machines off it as the need arises.
    I run my 5 hp lathe off a 3hp vfd with no issues, as stated earlier, hardly ever run at maximum cut.
