Hi Guys, need your kind help on double side grinding. I never use grinding machine before. May I know is there a possibility to grind flat plate (100mm x 100mm) from 3mm to 0.8mm using double sided grinding or double disc grinding? I've used end mill but very difficult to control warpage during milling due to imbalance stress develop during milling. So, I am interested to use double sided grinding to encounter this problem.
I've attached image milling using end mill. The material is torlon.
