Dressing stick use
Results 1 to 6 of 6
    Sep 2008
    Leics UK
    71
    11
    14
    Default Dressing stick use
    I remembered to put one of these on my latest order:
    I assume I hold it against the wheel, and on the side which will push it away, rather than suck it under.
    What else do I need to know?
    Dave
    Jun 2012
    Michigan
    11,621
    3968
    4132
    That a long stick can break so use with caution...angle it so it will not flip to the wheel diection or get caught in a pinch, know that it will leave a rough finish normally not good for a better/good finish, it is not the stone to just take off a glased wheel surface, it can get cracked with falling on a hard floor. It can be used to rough dress a wheel that will get a radius or angle dress so less wear on the diamond.
  3. Likes small.planes liked this post
    Jun 2012
    Tennessee USA
    917
    611
    535
    Drag it across the part of the wheel you want dressed or it will duplicate the stick profile if just held in one place on the wheel. Follow the advice in the above post. It can/will get hot too so be mindful of what skin it contacts like in the pocket of your pants.
    Nov 2014
    Florida
    4,511
    1730
    2162
    That kind are more suited to bench grinders. You need a diamond tipped dresser and block for a surface grinder.
    McMaster-Carr
    May 2006
    Seattle
    2,115
    50
    420
    Sometimes you want to cut with only the leading edge of the wheel. With a dressing stone like that, you can cut the wheel away everywhere except the leading edge very quickly. Same with side-wheeling.
    Those stones are *not* just for bench grinding.
    metalmagpie
    May 2010
    Indiana
    225
    51
    Make sure that you angle it down toward the wheel, and move it back and forth so it doesn't wear unevenly
