While looking for some better Phillips screwdrivers, I came across the Posidrive setup and some diamond coated Phillips bits. You can get a fair amount of diamond grit on eBay for $7 (1 carat / 2 gm 99.99% Diamond Polishing Powder 4 /5 Grit Mesh | eBay) and was thinking of just trying to improve some things around the shop / house.
I have diamond coated tweezers, Dremel burs, dental burs and so on. In doing some research, I have found 4 main methods of attaching / embedding diamond grit.
1. Sintering, mixing it with a low melting point metal / clay and firing it.
2. CVD, Chemical Vapor Deposition
3. Electroplating - Electroless Nickel Plating
4. Phenolic Resin
It is the last 2 options that seems most attractive since it shouldn't mess with the temper of the materials. The resin sounds easy, and should hold up well with something like tweezers, but seems it wouldn't work well for Dremel bits or Screwdriver bits, but maybe someone has some input on that.
Electroplating may work out, but from an articles I was reading I am not sure what kind amperage for a power supply to use if it is supposed to catch the diamond particles in a suspended state. There is the Electroless method (http://krc.cecri.res.in/ro_2002/065-2002.pdf), but from what I understand, the solution has a very short shelf life
Has anyone played with this that wouldn't mind some tips?
4. Phenolic Resin
