eliminating waviness altogether on small surface grinders - Page 2
Results 21 to 40 of 47
  1. #21
    Jul 2005
    Cottage Grove, MN 55016
    7,861
    4204
    4674
    I've never heard of magnetic aluminum???? You called it "aluminum heat sink". I have seen similar marks on steel when the mag chuck was not holding and the part slide a little. I am assuming you have the part on the mag on an angle. It almost seems your playing a joke here. A year ago one member was doing that. He Made up a fake identity and asked dumb questions until we discovered what he was doing. I hope this is not the case.
  2. #22
    May 2006
    Seattle
    2,116
    50
    420
    The part I ground was the flat piece of steel lying down. Standing on the part you see fingers that look vaguely like a comb. Those "fingers" are part of an aluminum heat sink attached to some computer memory that happened to be sitting on my desk when I was taking the picture.
    I did not grind any aluminum.
    I put the heat sink on the ground part not to play some kind of joke but rather because vertical elements in an image cause the autofocus in a digital camera to focus right there. In other words, I was forcing the camera in my phone to focus where I wanted it.
    I am very sorry that I confused anyone and I PROMISE I'm not some troll. I may be a newbie on this particular subgroup, but I have been around a long time. Being ignorant can give the appearance of being stupid, but ignorance is curable and I'm not stupid.
    metalmagpie
  3. #23
    May 2009
    Canandaigua, NY, USA
    3,017
    151
    1381
    I've spent a lot of years trying to cure my ignorance but I'm still a work in progress. Surface grinding, and probably most other forms of grinding, seem to be part science and part art form. Most people get results by trial and error, or were taught by somebody with more experience. The problem is that experience was achieved by... trial and error. I think grinding operations can be measured and analyzed. The profilometer tells you a lot, as do accelerometers on the machine. My experience is you can dress a wheel until the cows come home, but that won't make it balanced. What it does do is subtly shape the wheel to correspond to the vibration of the machine such that waviness is reduced. At least until something changes. What you really want is a round wheel running in balance and no vibrations. The lighter the machine, the fussier it is. IMO, you're on the right track.
  4. Likes eKretz liked this post
  5. #24
    Jan 2011
    Fairfield, PA
    398
    201
    196
    I don't know if this might help, but Cutting Tool Engineering's YouTube channel has some detailed videos on dealing with grinding problems. Maybe there is something there.
    YouTube
    Bill
  6. Likes metalmagpie liked this post
  7. #25
    Jan 2013
    Erie, CO
    183
    34
    17
    Trying slowing down on the last pass when dressing the wheel. It makes a big difference in the finish you end up with. Do let the part get any heat, if you can leave the part in a position so the air moved surface grinder wheel helps cool it.
  8. #26
    Mar 2005
    Indiana
    4,754
    1254
    1186
    Don't dress too slow or you'll end up with a closed wheel and burn marks, as well as more chatter. You kind of just have to arrive at the correct parameters via experience. There are lots of variables involved and you have to make adjustments to the relevant ones based on all of them.
  9. #27
    Jun 2012
    Michigan
    11,629
    3974
    4137
    I really dont understand the finish in poat #1, How does it feel running a ball point pen across in the cross direction. Can you feel that finish?
    What does a fresh dress wheel with just tickle grind with the full wheel and no cross Tavel,,so just dusting the part with full wheel..Take care to not get hot.
    What is the material that you are grinding?
  10. #28
    May 2009
    3,017
    151
    1381
    Those Grinding Doc videos are really good and confirm what I've thought about balance and egg shaped wheels. I have no coolant system on my 612 and that's probably the next thing to investigate.
  11. #29
    Jun 2012
    Michigan
    11,629
    3974
    4137
    I have done a ton of grinding dry and with not balancing...It just takes more care and more time...But for something as big and important as a chuck wet is best...even a drip bucket or hand spray.
    Yes I have even ground a chuck dry...just took a lot of time..and many gauges in the millionths..
    My buddy Don worked in a major shop mostly running high presision form spade drill points. and form lathe cutters..and the shop owner refused to use/allow any coolant on any grinder...
  12. #30
    May 2006
    Seattle
    2,116
    50
    420
    Quote Originally Posted by michiganbuck View Post
    Remember, that original image is magnified. No, I can't feel anything with a ballpoint pen or anything else. It feels way smooth. And it's a steel part.
    I can't do any more experiments for awhile because I'm tearing down my hydraulic unit. It gets too hot too fast. I'm expecting a very worn-out gear pump, and I'm hoping I can rebuild it.
  13. #31
    May 2006
    Seattle
    2,116
    50
    420
    Quote Originally Posted by majohnson View Post
    Try slowing down on the last pass when dressing the wheel
    Quote Originally Posted by eKretz View Post
    SLOW DOWN! DON'T GO TOO SLOW! What's a newbie to think? :-)
  14. #32
    Mar 2005
    Indiana
    4,754
    1254
    1186
    Well, dress fast for an open wheel when roughing. Maybe 1/2 - 1 second to get across a 1/2" wheel. Slow the dress down to 2-3 seconds across a 1/2" wheel for a pretty good finish. These numbers are for a sharp diamond! If you have a dull diamond they will be different and you need to keep the diamond moving faster. You can dress even slower for a better finish but you'd better be dusting low-tenths or less or you'll regret it.
  15. #33
    Jul 2005
    7,861
    4204
    4674
    Watch this. YouTube
    YouTube
  16. Likes eKretz, michiganbuck liked this post
  17. #34
    May 2009
    3,017
    151
    1381
    Good demo. That's about the speed I dress a wheel. Single pass only. I know people balance wheels by removing material, but I just can't get comfortable with it. I also know static balancing is the rule, but it's not near as good as dynamic. IMO, the smaller the grinder, the fussier it is.
  18. #35
    Mar 2005
    Indiana
    4,754
    1254
    1186
    That is a good dress for finishing. Conrad how do you dynamically balance your grinding wheels?
  19. #36
    Feb 2010
    ch
    2,490
    215
    329
    on the spindle, maybe?
  20. #37
    Nov 2014
    Florida
    4,511
    1731
    2163
    Not sure if this has been mentioned, but 'dull' diamond for dressing will leave poor results. Also, it can help to try a cluster diamond for dressing as well as a single point diamond.
    https://www.mscdirect.com/product/details/03502127
    https://www.mscdirect.com/product/details/03546454
  21. #38
    May 2009
    3,017
    151
    1381
    See my post #15 in the OP's previous question- grinding wheel nomenclature - how to you remember it?
    I use more sophisticated stuff than most people have, but any accelerometer that gives you a useful output will work. The 4-pass method doesn't require strobes or any worries about rotation, just that the thing runs at constant speed during the test. I suspect modern phones might even do it, with a suitable app, but have never tried it.
  22. Likes eKretz liked this post
  23. #39
    May 2009
    3,017
    151
    1381
    One of those grinding doc videos talked about clusters. Apparently they work well, but you have to traverse them extremely fast to get the desired results. Used like a single point diamond, they won't work right.
  24. #40
    Jul 2018
    New Hampshire
    69
    13
    I don't understand how a cluster can work. Unless it is extremely accurately
    aligned, doesn't one diamond to all the cutting? The other diamonds are just too
    far away to cut.
