eliminating waviness altogether on small surface grinders - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    Jun 2012
    Michigan
    11,754
    3999
    4186
    I have use clusters and they seem to work fine ..Seems with them not being place dead center or in the same radial turn makes them find a new facet...not sure why but they do work well.
    With setting a single point diamond on the/a spot location, perhaps with using a spacer to the long table stop one can easily see the wheel loss part to part, or for a given amount of stock taken so to gauge the wheel breakdown this to aid getting nearer to finish size with fewer measuring’s takes. Also using a spotter to spark-on near size can save much grinding time. I would place a tab of masking tape on a spotter with a sharpie X so seeing the wheel hit I would be about .0035 off the part finish height. The time to dress to cool the part and come in for finish with taking tickle to grease pencil mark on that same spotter would make size .0002 or so close with not taking any measure.
    OT: hAS ANYONE TRIED THE BARGAIN SINGLE POINT DIAMONDS OFFERED ON eBAY?
  2. Likes AD Design liked this post
  3. #42
    May 2006
    Seattle
    2,123
    50
    428
    Does anyone have a diamond holding block they like, one that can be used down low on the face of the wheel, or up higher to dress the sides?
  4. #43
    Jun 2012
    Michigan
    11,754
    3999
    4186
    I like a bar dresser about 1" x 1 1/2 x 3 1/2 long with a 3/8 diamond hole at 15* angle and set screw in the 1" and 1 1/2” side.
    It can set on the chuck or be double clamped to a block. with having a screw hole, it can be screwed to an angle plate having a few screw threads holes. also, it can set on an angle plate bar so to hand-slide to grind an angle. Simple home made of CRS is good/ok.
    I have used the Eagle Rock swing-arm dresser with success…but don’t own one.
    Eagle Rock Tech Wheel Dresser Grinding | eBay
    This a bargain for $30
  5. #44
    May 2006
    Seattle
    2,123
    50
    428
    Quote Originally Posted by michiganbuck View Post
    Missed that one.
    Is this kind of what you are describing? metalmagpie
  6. Likes michiganbuck liked this post
  7. #45
    Feb 2010
    ch
    2,501
    215
    329
    "OT: hAS ANYONE TRIED THE BARGAIN SINGLE POINT DIAMONDS OFFERED ON eBAY?"
    i use nothing else, but as i mentioned elsewhere, i grind sparingly.
  8. #46
    Feb 2010
    ch
    2,501
    215
    329
    conrad, the spreadsheet you linked to (post #15 in other thread) doesnt work. it would be interesting to see the calculations.
  9. #47
    Feb 2020
    73
    29
    Quote Originally Posted by Mr_CNC_guy View Post
    I don't understand how a cluster can work. Unless it is extremely accurately
    aligned, doesn't one diamond to all the cutting? The other diamonds are just too
    far away to cut.
    clusters are handy when useing the full face in a plunge situation
    such as a 20 inch centerless with a stacked set of wheels that dosnt have a
    recyp head
    saves a lot of polishing
    have seen 2 inch bar clusters
    they have fully adjustable mounts and are a bitch to get setup properly
    have seen some spectacular wrecks from folks that leave everything loose and
    try to float clusters in
    in conventional step over surface grinding you dont grind with the full face just the
    leading edge that is breaking down
