Can anyone comment on things I need to look out for when using very fine grit grinding wheels?
In my application, I'll be using wheels down to 0.5um grit size, grinding semiconductor parts, so a mix of epoxy/silica, copper, fiberglass, gold.
Will I have issues with clogging the wheel? Can a higher pressure coolant help with this?
Any guidelines with cut depth, and feed rates?
Matt
Matt
