atomarc
- Mar 16, 2009
- Eureka, CA
I have a hardened shaft I need remove about .0004 tenths from the OD. It's hardened and ground but a smidgen too big. I plan on doing it on my lathe using a toolpost grinder. Not the best setup, that all I have.
Is there a preferred method as I slowly rotate the chuck..in the direction of the stone rotation or against the stone rotation. I plan on using the powerfeed to slowly traverse the short distance to be ground. Does this sound OK?
Stuart
Stuart
