ballen
- Sep 25, 2011
- Garbsen, Germany
When you have a part that's too long for the chuck, is there a rule of thumb about how to overhang it off the chuck and grind it in stages?
I ask, because this weekend I ground some 600mm (24") parts for a friend, on my J&S 540 surface grinder (long traverse 450mm = 18"). I had to grind each part in two passes, shifting and blending.
At first I had the parts hanging off the left side of the chuck. So when the table was at the far right, the grinder reversed direction on the part. But when I was done, I found that the "reverse points" had dug a hole about 20 microns (0.0008") deep in the part. Fortunately I had no spec for total thickness, so I shifted the part so it overhung on the right side of the chuck, and did it again. This time, all went fine, the reverse on the part happened when the table was at the far left, and it did not "dig a hole".
I'm wondering if there is some effect like climb cutting that happens when you reverse on a part on one end of the long traverse that causes the wheel to dig in, but not if you reverse at the other end.
