Grinding Stainless Steel vs 'standard' Steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Feb 2013
    Italy
    37
    9
    Default Grinding Stainless Steel vs 'standard' Steel
    Hi! I'm working on a DIY project that involves grinding SS material.
    Apologies for not being precise in the description of the material - all involved materials are just generic hardware store type.
    Question is whether a 'diamond' wheel is better than an abrasive wheel. Are there specific abrasives for SS compared to steel?
    Also, is SS more difficult to grind than steel?
    Thanks in advance!
    Jul 2006
    Hillsboro, New Hampshire
    13,588
    2993
    9117
    Diamond (or CBN) will not be good choices for generic stainless. We have people on this forum who are much better than me at suggesting abrasive wheels for specific applications, but if none of them comments then you should find a representative for a grinding wheel manufacturer in your country and get in touch with them for advice.
    May 2009
    Canandaigua, NY, USA
    3,283
    172
    1599
    Need more info. What kind of grinding? Bench grinder, surface grinder or something else. Amount of material to be removed and finish needed? Magnetic or non-magnetic stainless? I grind "generic" stainless on my surface grinder with an ordinary AlOx white wheel. If you were going to take much off, coolant would probably be essential.
  4. Likes michiganbuck liked this post
    Feb 2013
    Italy
    37
    9
    Quote Originally Posted by Conrad Hoffman View Post
    Well...that's where it gets complicated. I've built a kind of grinding apparatus on the workpiece.
    The workpiece is the black 'semicircle' that is hanging via 2 steel beams. It's carbon/plywood/foam multilayer sandwich with a strip of 2mm SS running bonded to the perimeter (yellow dotted line). The SS strip is 1.5m long, 110mm in height and the runout is 0.6mm
    You can see the apparatus that can swivel around a pivot on block bearing while the 'grinding' part is powered with a router. The movement is manual....I mean, by hand literally.
    As of now the grinding action is provided by a d.20mm ground shaft, again on block bearings with #40 sandpaper superglued to it. The superglue part actually works just fine but the material removal is painfully slow. To be honest this is a one-off machining so I don't care spending hours to get it done.
    The problem is that the action is not 'smooth', at least in the direction where the grinding tends to stall as it's "gearing" into the SS strip if it makes sense.
    I image this is not easy to understand and digest - I might need to upload a video n YT and post here the list to give a decent idea.
    The original question is related to the fact that I feel that if I could make a tool by piling some 2" or 3" grinding discs -and possibly dressing them on a lathe- I can have a better chance. BTW the shaft position can be finely adjusted and I don;t have much problem in getting it precisely parallel to the machining surface
    May 2009
    3,283
    172
    1599
    Not sure what to suggest. That just looks wildly inadequate to the task. I've done similar things by screwing them to a rotary table on the mill and milling them. That would probably end up as good or better than the sanding/grinding arrangement. You could use a reduced shank end mill so the cutting width was manageable for each pass. Or maybe attach your part to a pivot on a belt sander and rotate it against the belt. I don't think even a big router is going to get you where you want to go.
    Jul 2006
    13,588
    2993
    9117
    Out of the option offered I'd go with this. Skround, I admire your ambition, but you don't really have the tools at hand to do what you want efficiently. Either continue as you are, or try Conrad's belt sander option.
    You could try changing the direction you move the sanding apparatus from one direction to another, I'd suggest moving such that the 20mm rod is trying to "push away" from the work. That may help with the "gearing" you mentioned.
    You could also try setting up a spray mechanism to blow a very light stream of water into the cutting area (try to contain it there) to allow the sandpaper to cut more efficiently and reduce heat. Just a small amount would help. Even better would be to add a small amount of machining coolant additive to the mix, but for the small amount of work you're doing I think you could skip it.
  8. Likes michiganbuck liked this post
  9. #7
    Jan 2007
    Flushing/Flint, Michigan
    10,575
    619
    8543
    Given your setup a sanding drum is maybe the best which is what you have made other that the "bump" at the paper end or edge.
    You say it bites, direction used may influence this as in climb or conventional milling.
    Bob
  10. #8
    Feb 2013
    Italy
    37
    9
    I'm not looking for a bigger router but rather a larger effective grinding tool to be adapted on the 20mm shaft. It might do the trick - or not.
    A belt sander doesn't look viable - the workpiece is 4ft diameter and there's little chance to swivel it around.
    This is the kind of 2" or 3" abrasive 'disc' I'm thinking about - some of them comes with 20mm ID so I can bond them to a shaft:
    I could split the entire height in 3 passages to take care of the 0.6/0.7 run-out and then final passages with finer grit with the full height 20mm shaft.
    The original question is about the grinding material and so far I understand CBN is not good whereas AlOx is a good one.
  11. #9
    Feb 2013
    Italy
    37
    9
    Bite! That's what I meant for 'gearing'. I can actually find a way to always go in the same direction - that's not a huge big deal. (What I think it's) my problem is that the material removal rate is agonizingly low hence looking at abrasive discs with larger diameter
  12. #10
    Feb 2013
    Italy
    37
    9
    Yes that's ambitious - I could take it to a CNC workshop but part of the project is to identify a way to do this operation on a DIY level, despite being sophisticated.
    I have my own doubts - that I use to address issues one by one- but I'm naive to machining operations. I've been dealing will CNC machinery for as long as I remember.
    Btw, I am the spray mechanism! I have a spray bottle while my friend is pushing the router around
  13. #11
    Jul 2006
    13,588
    2993
    9117
    Quote Originally Posted by skround View Post
    You have a good friend. I hope he gets a nice bottle of wine or something at the end of the day.
  14. Likes skround liked this post
  15. #12
    May 2011
    New Jersey
    2,999
    301
    1652
    What kind of half-assed crap is this...
  16. Likes skround, Janderso, rotarySMP liked this post
  17. #13
    Feb 2013
    Italy
    37
    9
    Quote Originally Posted by plastikdreams View Post
    even quarter-assed, BUT
    the original question was as simple as what's the right abrasive material for SS steel and if it's really worse than a low-alloy steel run-of-the-mill steel.
  18. #14
    Jul 2006
    13,588
    2993
    9117
    Yes, generally stainless is more difficult to grind than "regular" steels, due to the chromium and nickel alloying elements (and others), as well as it's gumminess and poor thermal conduction properties (300 series).
  19. Likes skround, michiganbuck liked this post
  20. #15
    Aug 2005
    South Australia
    237
    27
    47
    Hi Skround, If I were doing what you are I'd arrange the workpiece to move on a pivot rather than the 'tool'. For the 'tool' I'd use a fixed vertical linisher .. the rationale is lots of 'tool' as in belt, to last the distance. No worry about 'self feeding' linishing across the feed direction. With the flat vertical bed the linisher only has 'line contact' so less heating of the stainless.. allowing more aggressive feed, but keeping that heating in mind all the same. I dare say you don't want to de-bond the stainless. Anyway I reckon a 'cross grind' on 'line contact' is the way to go, being 'feed neutral', you simply feed as the belt is able to cut. I'm sure there would be belts specific to stainless just as are cut-off wheels/discs. Consult with an abrasive company .. perhaps Pferd? If desired you could modify the 'lay' of the grind manually with a sanding block after 'machining'.
  21. #16
    Mar 2011
    Huron
    1,458
    2536
    918
    As Swarfless said, I would ditch the idea of "grinding" and look into a belt (or square wheel) sander, massively more abrasion material and feed. If you are looking to remove material, you can go super low on the grit and really chew through it, if you are looking for size or finish you can run belts right up to polishing grade.
  22. #17
    Feb 2013
    Italy
    37
    9
    Thanks for the replies all - need to digest them a bit and I'll come back with few questions.
    In the meantime I've uploaded a short video just for the sake of giving a better idea of the set-up and the issue
    800mm Telescope Project - Grinding Pac-Men - YouTube
  23. #18
    Jun 2008
    VA
    809
    210
    326
    I’d just avoid climb cutting, back off the feed and move back to the start. Or at least that is what I would do if I had to do what you’re doing, which I wouldn’t, I’d cobble something on the Bridgeport. I don’t know what kind of precision your expecting from the fixture let alone the humidity sensitive composite you attached the SS strip to...
  24. #19
    Jun 2012
    Michigan
    13,843
    4715
    4978
    If the part top is smooth you might add a follow roller or a follow point to ride the part, an air blow might keep grinding grit from bouncing the travel follow device.
    An abrasive wheel that can be dressed and adjusted for height would /might be better than abrasive paper.
    What tolerance do you need?
    I have not had luck with CBN for SS, A course large grit and soft bond natural diamond wheel is Ok for a small take amount but an expensive process.
    I used a wet Radack pink grinding wheel with success on SS... but now forget the grit and grade.
    Oh, I see you have a follow roller. that is a decent Rube Goldberg set-up.
    Likely I would mount a grinder and then turn/rotate the part. white aluminum oxide wheels usually grind SS better than most others.
    The current grinder/router motor could have a bearing mounted above and below the part as any run-out will deter good grinding.. Stalling so to reduce the speed of surface feet per minute is a deterrent to any grinding action.. and stalling likely will lose some accuracy needed for decent spark-out.
    Most SS acts like hard steel and tends to try to stall the wheel with rapid heat expansion so sucking into the wheel. Higher horsepower is often needed to keep wheel RPM at needed RPM, and coolant helps keep down heat expansion. A coarse grit and softer wheel or frequent dressing the normal wheel can help. Normal hardness is H through L
    Still you have my complements for building something that works.
  25. #20
    Feb 2018
    88
    47
    24
    I like the term clap-trap.
