rbleth51
- Apr 22, 2008
- Maine, USA
Good afternoon all.
So I finally have my new (to me) Harig Super 612 home, unloaded and in the garage. It is not in the shop yet as the snow is piled way too high and the ground is way too soft from the "warm" days to move it in yet.
In the mean time I have begun the cleaning process and started digging into things to see exactly what I got in the deal.
When I bought it I was told by the previous owner that the oil pump was bad. In researching here and elsewhere on the web it appears that this might have been kind of a common problem. I got the pump out and started looking things over. The wiring comming out of the pump has a plug on the end of it. However I do not have a socket that fits it. After some rumaging through the odds and ends in the cabinet I found an electical cord with a matching socket on the end. It was marked for 125V. Someone had spliced on another cord with a common 120V household style plug on it. When plugged in the pump quietly hummed. But I could not tell on the bench if it was actually spinning. I removed the botom of the unit to expose the rotor and it is in fact spinning. This leads to a couple of questions.
Can anyone tell me from the picture below if this is a factory Harig pump? It does not look like the pumps I have seen in pictures here.
