Harig Steptool Relief Grinding Fixture Alignment Bar
Results 1 to 7 of 7
    Jan 2005
    San Francisco Bay Area
    277
    19
    Default Harig Steptool Relief Grinding Fixture Alignment Bar
    I have a Harig Steptool relief grinding fixture but not the alignment accessory used to time the workpiece to the cam. I found a picture of the accessory but I have been unable to figure out how it is used. Can anyone give me some tips on making and using an alignment fixture?
  2. Likes gerritv liked this post
  3. #2
    Mar 2016
    CANADA
    Ontario
    120
    113
    69
    I'm disappointed that no one has responded, a friend and I are trying to figure out the same accessory. Seems items such as this never make it with the sale of the main item.
    Gerrit
    Jun 2012
    Michigan
    9,789
    3312
    3514
    All the step tool fixtures I have used the alignment fixture is simply a center finder so at the peak of the cam your cutting lip is on center.
    So just an eyeball use post or a post with a short swing horizontal finger to show the fixture center line.
    With a tilt fixture (not Harig step tool) the alignment fixture sets its base off the fixture spindle not off the table.
    Many grinder hands just eyeball the lip to be horizontal with not using the alignment fixture so still being well with-in 1/2 degree, the Ok angle in a non specified angle tolerance..
  5. Likes gerritv liked this post
  6. #4
    Jul 2005
    Cottage Grove, MN 55016
    7,510
    4066
    4490
    I found these . You need to be more patient too as many of us don't look daily on here.
    http://vintagemachinery.org/pubs/2804/4250.pdf
    http://vintagemachinery.org/pubs/2804/4249.pdf
    You may want to put and ad on Vintage Machinery and someone there might have info too.
  7. Likes gerritv, cash liked this post
  8. #5
    Mar 2016
    CANADA
    Ontario
    120
    113
    69
    Thank you michiganbuck, that helps. The manuals are useless, mainly advertising style.
    Richard, I am not the original poster but thought 4 days was fairly patient :-) The patent is actually more useful than the 'manuals', I even bought what was supposed to be a manual and it was just a bunch of hints. Not very helpful if you don't already know how to do this. US2958167A - Grinder fixture
    - Google Patents
  9. #6
    May 2018
    Virginia
    Default I think u are referring to a lip positioned that my be Hargis terms however if you
    Quote Originally Posted by lathehand View Post
    However if that does not help & if we can get in touch on the phone I can walk you through this & possibly can get desired results I will monitor this forum For a few days & u can reply (fishman help) I will send you my phone # good luck
  10. #7
    Jun 2012
    Michigan
    9,789
    3312
    3514
    alignment accessory
    Put your step tool on a plate. Height measure from the plate to the center line of a chucked cutter.
    Next make a 1/2 x 3/4 x 1 1/4" CRS block..(about).. To one side of the 3/4 x 1 1/2 face, ream a 3/8 hole.
    Make a 3/8 rod to the 1/16 shorter than length of the height measure. and drill and tap a 10/32 in one end.
    Drill/tap a set screw in the side of you block to hold the 3/8 rod vertical with the 10/32 pointing up.
    Make a locator 1/4 wide 1/8 thick x 1" long with a hole for a 10/32 screw at flat center.
    Grind one end of locator so taking off 1/16 so making your step-tool center line locator when it is mounted to the top end of the 3/8 rod.
    You eye ball the cutting edge of your cutter to the locator when your cam is in the fall away position for grinding clearance to a cutter. (just in side the fall away position is best.0
    Most often one will butter-fly (back and forth) all the cutting lips in a circle grind fashion.
    Then locate each tooth to the cam and grind, bring the cam relief up to just making the edge sharp.. doing same to each tooth edge insures all the lips are spot-on being the same.
