Help with cutting and grinding carbide
Results 1 to 11 of 11
    Aug 2013
    Illinois
    10
    Default Help with cutting and grinding carbide
    What we usually use are 5/16 or 3/8 diameter M2 round blanks and grind our emboss shape on the tip of the punch and a flat on the side for a set screw to align. Now that we are hitting hardened steel, we are wanting to change to carbide instead for our punches.#1 What do you use to cut through carbide? #2 What type of grinding wheel will cut carbide and is able to have a radius dressed on it? #3 What do you use to dress the wheel? I have never worked with carbide before and need as much info as i can get on the whole procedure. Any and all help is greatly appreciated. Thanks
    May 2011
    New Jersey
    1,599
    148
    837
    Wire or sinker edm, some lasers, some waterjet will cut it...you need a diamond wheel to grind it.
  3. Likes cash, pianoman8t8 liked this post
    Mar 2013
    NW Pa
    357
    52
    150
    Keep in mind carbide is very hard and brittle ,I would guess the first hit would send out bullet like projectiles in every direction.
  5. Likes mc3608, Paolo_MD, sfriedberg liked this post
  6. #4
    Jan 2013
    Plainfield, Indiana, USA
    1,678
    1260
    904
    Think of using glass instead of carbide . . . works about the same. DON'T HIT IT OR HIT ANYTHING ELSE WITH IT, ESPECIALLY HARDENED STEEL!
  7. #5
    Jun 2012
    Michigan
    9,250
    3142
    3324
    Thin perhaps 1/32" surface grinder wheel running wet will cut 5/16 and 3/8 carbide rod very well. You set the wheel over and using down feed only cut right through at a down-feed rate that does not show the spindle. This will leave a small bug/burr at the bottom of the fall off portion owing to the slight radius that is likely to wear onto the wheel. Have a catch basket so the falling part does not damage you chuck surface.
    Agree carbide is so hard and subject to fracture you need to have all facets well rounded and punch a soft material, wear safety glasses and have the work area well shielded.
    Likely a cast iron C2 grade would be best, but chancy that it would work with not shattering.
  8. Likes pianoman8t8 liked this post
  9. #6
    May 2011
    New Jersey
    1,599
    148
    837
    I'd look into something like cpm 10v or 15v...those make some pretty tough dies
  10. Likes cash liked this post
  11. #7
    Jan 2007
    Flushing/Flint, Michigan
    7,094
    341
    5999
    You want to grind carbide with diamond wheels.
    Available in and shape or rad you want or need,
    The carbide is available in a in many grades also but punch work is either C-2 or C-10. Weird that the numbers are so far away while similar, one of these like impacts and is not the carbide you make lathe or mill cutting tools from.
    I have very little idea of how to help without a pic of just what you want to hammer or stamp into the part.
    Done wet with diamond I think you will find the grinding much easier than working in M2.
    Bob
  12. #8
    Apr 2013
    Damascus, MD
    1,342
    3805
    755
    Have you considered other "stamping techniques", like electrolytical etching, or somehow rudimentary plunge EDM, or simple engraving? How deep do your punch marks need to be? How many items?
    Yes, both electro-erosion techniques are fairly slow. But, at least the equipment for electrolytical etching is rather cheap and easy to multiplex.
    Paolo
  13. #9
    Jun 2012
    Michigan
    9,250
    3142
    3324
    CPM steels may be a better choice than carbide. They are very hard, wear resistant and more shatter prone
    Carpenter Technology Corporation
    High Speed Steel | 3V Tool Steel | 3V Steel | CPM 3V
  14. #10
    Nov 2012
    Maine, USA
    375
    1624
    56
    For what it's worth, we also grind Carbide here (cylindrical grinding) in the 3" up to 8" dia range. In the past few years a few jobs have trickled in that required profile/form grinding. We were able to dress and true corner rads via rotary dressing with yet another grinding dressing wheel. Expect much wear on the dresser wheel while dressing. But, this sounds like a different application.
  15. #11
    Jan 2007
    7,094
    341
    5999
    Quote Originally Posted by cmccull166 View Post
    Only if you pick the wrong tungsten carbide grade.
    Yep, cutting tool carbide blends make for terrible hammers.
    Large grain size and lots of cobalt are where you build pulverizing and recycling hammers.
    Punches are application specific but the stuff you would make a endmill out of is maybe not a good choice.
    But available cheaper and sometimes perfectly okay in light stamping of a logo or mark if the side angles and depth are good.
    Perhaps all this confusing for the OP.
    Bob
